> Roll couple and rear tire spin
yeahmag
post Feb 19 2018, 06:09 PM
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up:
Front:
21mm torsion bars
19mm sway bar set 3/4 hard
Rebel Racing Bushings
Monoball camber plates
19mm raised spindles
Bilstein Sports
2.5 degrees camber
5 degrees caster
1/16" toe out
Rear
225lb springs
No rear bar
Koni Yellows (full soft)
2.0 degrees camber
1/16" toe in
Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot.
Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction?
Me
https://www.youtube.com/watch?v=hdMUYqusga4
Evan (damn he's fast)
https://www.youtube.com/watch?v=mI6O_gVzPuA
yeahmag
post Feb 20 2018, 03:33 PM
(Let me know if you get sick of talking about this...)
Chris, That seems counterintuitive to me. The heavier springs (8" coilovers) can't hold the wheel up. A sway bar certainly can and would (on the same axle). The spring can ONLY push DOWN (or hold the car up depending on how you want to discuss it). Is the idea to use the diagonal to hold the opposite corner (on diagonal) down?
Brant, It has has a Mad Dog stiffening kit and some suspension stiffening - no cage.
Scott, probably only around 130HP, but I've not dynoed it.
ChrisFoley
post Feb 20 2018, 04:11 PM
I am Tangerine Racing
QUOTE(yeahmag @ Feb 20 2018, 05:33 PM) *
Yes.
914s are inherently rear grip limited so doing anything which takes away grip at the rear is usually a bad choice. Stiffer springs take away grip.
If you can't increase your anti-sway bar stiffness, can you install 22mm front torsion bars? IMO, 225lb rear springs are not that well matched with 21mm fronts anyway.
yeahmag   Roll couple and rear tire spin   Feb 19 2018, 06:09 PM
Krieger   I think your going in the wrong direction. Try 18...   Feb 20 2018, 12:23 AM
yeahmag   The idea is to keep the wheel with the weight on i...   Feb 20 2018, 12:45 AM
Racer Chris   The idea is to keep the wheel with the weight on ...   Feb 20 2018, 01:41 PM
Racer Chris   Tighten the front bar and try that before making a...   Feb 20 2018, 07:34 AM
stownsen914   I agree with your thought to use heavier rear spri...   Feb 20 2018, 09:45 AM
yeahmag   Chris, the bar is set to 3/4 hard, so I only have ...   Feb 20 2018, 12:19 PM
Racer Chris   Stiffer rear springs isn't going to help the r...   Feb 20 2018, 01:35 PM
yeahmag   Yup. Full soft (Koni Yellow). I'm not really h...   Feb 20 2018, 01:37 PM
brant   I'm also wondering if you have a cage in this ...   Feb 20 2018, 02:32 PM
stownsen914   Sorry if I missed it, but what kind of horsepower ...   Feb 20 2018, 02:52 PM
sixaddict   Once Chris speaks ---I listen !   Feb 20 2018, 02:58 PM
yeahmag   (Let me know if you get sick of talking about this...   Feb 20 2018, 03:33 PM
Racer Chris   Is the idea to use the diagonal to hold the oppos...   Feb 20 2018, 04:11 PM
yeahmag   Chris, I'll see if I can "get" that ...   Feb 20 2018, 05:16 PM
Racer Chris   ... Do you have a preferred set up for an aggress...   Feb 20 2018, 07:58 PM
brilliantrot   I thought Aaron's car felt pretty darn good an...   Feb 20 2018, 06:27 PM
Cracker   I haven't seen this...LSD or TBD in the car no...   Feb 22 2018, 10:04 AM
Racer Chris   I haven't seen this...LSD or TBD in the car n...   Feb 22 2018, 10:09 AM
Cracker   One of my race cars has 80 ft lbs torque and has a...   Feb 22 2018, 11:04 AM
yeahmag   I do think an LSD would help this car, just way, w...   Feb 22 2018, 11:49 AM
pcar916   My car is where I like it on a road course, and go...   Feb 23 2018, 06:01 AM
yeahmag   I'm constantly tweaking tire pressures, but we...   Feb 23 2018, 11:45 AM
pcar916   I'm constantly tweaking tire pressures, but w...   Feb 23 2018, 05:45 PM
yeahmag   I may have a line on a 22mm sway bar (Gerold) and ...   Feb 23 2018, 05:52 PM
stownsen914   So I'll throw this out there ... years ago wh...   Feb 25 2018, 09:52 AM
sixnotfour   :driving:   Feb 25 2018, 04:01 PM
sixnotfour   flat 8   Feb 25 2018, 04:02 PM
- Lo-Fi Version Time is now: 4th July 2025 - 01:25 AM
