> what to use for silicone remover, mineral spirits NLA in Calif EDIT: solution found.
914 RZ-1
post Feb 20 2018, 05:12 PM
Porsche Padawan
Mineral spirits are NLA in SoCal. What do you all use to clean off silicone? I've scraped all I can; I need to get the rest off.
Goo Gone supposedly works, but I tried it and it didn't seem to do much. Maybe I have the wrong kind.
I need to remove it from the rear window and from around the rear window frame on the car.
EDIT: I found a solution. I used Motsenbockers Lift-off. It apparently works by loosening the molecular bond. I scraped off as much as I could with a razor. I applied the lift-off. Let it sit for about 3-5 minutes. I was then able to scrub it off with a rag. Took about 3 applications.
The flour just made a mess! The other suggestions did not work for me.
This post has been edited by 914 RZ-1: Mar 11 2018, 08:19 PM
Nacho
post Feb 20 2018, 06:21 PM
QUOTE(914 RZ-1 @ Feb 20 2018, 06:12 PM) *
I just ordered Mineral Spirits from Amazon with no issues delivered to my house in SoCal.
914 RZ-1   what to use for silicone remover   Feb 20 2018, 05:12 PM
Marty Yeoman   Try charcoal lighter fluid.   Feb 20 2018, 05:42 PM
burton73   You have to scrape it. It grabs by capillary actio...   Feb 20 2018, 05:57 PM
914 RZ-1   It's around the rear window area. I do not wa...   Feb 20 2018, 10:05 PM
burton73   It's around the rear window area. I do not w...   Feb 20 2018, 10:25 PM
burton73   Even acetone will not eat it. You have to rub it o...   Feb 20 2018, 06:10 PM
Nacho   Mineral spirits are NLA in SoCal. What do you all...   Feb 20 2018, 06:21 PM
Jeff Bowlsby   How about using petrol?   Feb 20 2018, 07:30 PM
boxstr   I have had success using a clear marine type of ad...   Feb 20 2018, 07:37 PM
914 RZ-1   What about any products available at the big box s...   Feb 20 2018, 10:12 PM
sb914   RE: what to use for silicone remover   Feb 21 2018, 07:08 AM
76-914   What? Hard to believe but I’ll try it next t...   Feb 21 2018, 09:21 AM
Krieger   Mineral spirits are NLA in SoCal. What a bunch ...   Feb 21 2018, 08:56 AM
Mueller   Mineral spirits are NLA in SoCal. What a bunch...   Feb 21 2018, 09:30 AM
914 RZ-1   I found a solution. See first post edit.   Mar 4 2018, 09:40 PM
larryM   excellent - thanks for sharing! What do you...   Mar 9 2018, 10:40 PM
burton73   Thanks for running this down and teaching us. Bo...   Mar 9 2018, 11:00 PM
76-914   :agree: Wish I had known this a couple months back...   Mar 10 2018, 02:57 PM
amfab   FYI Mineral Spirits is now banned within the South...   Mar 11 2018, 12:21 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:39 PM
