| 914 RZ-1 |
Feb 20 2018, 05:12 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
Mineral spirits are NLA in SoCal. What do you all use to clean off silicone? I've scraped all I can; I need to get the rest off.
Goo Gone supposedly works, but I tried it and it didn't seem to do much. Maybe I have the wrong kind. I need to remove it from the rear window and from around the rear window frame on the car. EDIT: I found a solution. I used Motsenbockers Lift-off. It apparently works by loosening the molecular bond. I scraped off as much as I could with a razor. I applied the lift-off. Let it sit for about 3-5 minutes. I was then able to scrub it off with a rag. Took about 3 applications. The flour just made a mess! The other suggestions did not work for me. ![]() This post has been edited by 914 RZ-1: Mar 11 2018, 08:19 PM |
| JeffBowlsby |
Feb 20 2018, 07:30 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
How about using petrol?
914 RZ-1 what to use for silicone remover Feb 20 2018, 05:12 PM
Marty Yeoman Try charcoal lighter fluid. Feb 20 2018, 05:42 PM
burton73 You have to scrape it. It grabs by capillary actio... Feb 20 2018, 05:57 PM
914 RZ-1 It's around the rear window area.
I do not wa... Feb 20 2018, 10:05 PM
burton73
I do not w... Feb 20 2018, 10:25 PM
burton73 Even acetone will not eat it. You have to rub it o... Feb 20 2018, 06:10 PM
Nacho
Mineral spirits are NLA in SoCal. What do you all... Feb 20 2018, 06:21 PM
boxstr I have had success using a clear marine type of ad... Feb 20 2018, 07:37 PM
914 RZ-1 What about any products available at the big box s... Feb 20 2018, 10:12 PM
sb914 RE: what to use for silicone remover Feb 21 2018, 07:08 AM
76-914
What? Hard to believe but I’ll try it next t... Feb 21 2018, 09:21 AM
Krieger
What a bunch ... Feb 21 2018, 08:56 AM
Mueller
What a bunch... Feb 21 2018, 09:30 AM
914 RZ-1 I found a solution. See first post edit. Mar 4 2018, 09:40 PM
larryM excellent - thanks for sharing!
What do you... Mar 9 2018, 10:40 PM
burton73 Thanks for running this down and teaching us.
Bo... Mar 9 2018, 11:00 PM
76-914 :agree: Wish I had known this a couple months back... Mar 10 2018, 02:57 PM
amfab FYI Mineral Spirits is now banned within the South... Mar 11 2018, 12:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:12 PM |
