What is this undercoating material, Not your normal rubber stuff |
Mikey914 |
Feb 25 2018, 01:13 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So cleaning up the bottom of the car to assess the entire car, and found this material that looks like a light coat of primer. It has enough grime on it to be original.
My question to anyone that was around when these were coming out of the dealerships is; what is it, and what was it supposed to do? There is no rust so it certainly worked, but this was a Nevada car all its life. Mr Mayer perhaps you have an idea? Attached thumbnail(s) |
Tom_T |
Feb 25 2018, 12:29 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Hey Mark -
I have to disagree with my esteemed fellow members on this, after both having been around back then (as was Mark/914sixer), & renewed research in recent years for my own 73's resto. The factory undercoating was similar to what was used on the valances & rockers panels (& on the black painted 73-74 steel bumpers), a heavy eggshell texture, which was then painted over in body color on the underbelly & wheel wells, & black at the rockers/valances/bumpers. The black spray-on coatings at the belly & wheel wells was a dealer applied "rust proofing" of varying reliability, & went by Zybart & a few other brand names (Zybart also had the drill-n-fill rustproofing too). Dealers would often do the spray coating on most/all cars without buyer request because it was quick & east to spray it on & most dealers had franchises with the suppliers, so that they could charge for it with 40-60% profit margin, but usually left the drill-n-fill to customer request because it was very time consuming & more expensive to do it. The black spray was basically like today's formulatiuons for the semi-rubbery rattle can & roll-on/spray-on underbody coating & bed-liners. My 73 914-2.0 had it put on before the original owner whom I bought it from even got the car, as well as having had 2 prior topside resprays from the factory L80E Light Ivory, first to Sahara Beige (like Steve's/smg - which the owner & I were unaware until I stripped some areas), then to the 72 Gold metallic when they & I bought it (OO only knew of the gold respray, but white was/is clearly visible on floor pans, etc.) - probably to try to sell it in better non-white colors. I always liked the "black-out" look in the wheel wells. It did protect my underside from rust here in SoCal, & 72-76 were what's now known as El Nino years too, & several while it was my & the OO's DD up to May 85. The underside rust which did form was due to window washer bottle & M/C leaks into the front trunk wells, & rusting from the inside down. You may recall the pix posted by Tod914 stripping the black coating off of his pristine Bahia 73-2L, & of Steve/smg stripping it off of his Sahara Beige when he got it. I think that their posts had some product(s), procedures & methods advice on how to clean it off best, & with least underlying paint damage. So I'd suggest a google search to read up more there. PS - To clarify - the gray stuff looks like it could be the body color paint worn off of the factory undercoating, but I was answering you about your question on the black stuff, which lies on top of the paint, then factory undercoating. Have Fun! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 1st June 2024 - 04:42 PM |
