> Roll couple and rear tire spin
yeahmag
post Feb 19 2018, 06:09 PM
Just got through my first autocross after the rebuild and the car was great! With a good friend and hot-shoe behind the wheel the car was the 2nd fastest aircooled car and #7 PAX adjusted in a pretty big field (PCA OCR).
I'd like to get better control of the rear, inner tire. We were spinning it up quite a bit. I'm thinking more rear spring is the correct approach. Current set up:
Front:
21mm torsion bars
19mm sway bar set 3/4 hard
Rebel Racing Bushings
Monoball camber plates
19mm raised spindles
Bilstein Sports
2.5 degrees camber
5 degrees caster
1/16" toe out
Rear
225lb springs
No rear bar
Koni Yellows (full soft)
2.0 degrees camber
1/16" toe in
Tires are fairly used up Hankook C71 Z214 in a square set up (205/50-15) run at about 22lbs hot.
Granted replacing the tires would help, but even when they were new it would spin these up. I have 275lb springs sitting around that I can swap in. Am I heading in the right direction?
Me
https://www.youtube.com/watch?v=hdMUYqusga4
Evan (damn he's fast)
https://www.youtube.com/watch?v=mI6O_gVzPuA
sixnotfour
post Feb 25 2018, 04:01 PM
yeahmag   Roll couple and rear tire spin   Feb 19 2018, 06:09 PM
Krieger   I think your going in the wrong direction. Try 18...   Feb 20 2018, 12:23 AM
yeahmag   The idea is to keep the wheel with the weight on i...   Feb 20 2018, 12:45 AM
Racer Chris   The idea is to keep the wheel with the weight on ...   Feb 20 2018, 01:41 PM
Racer Chris   Tighten the front bar and try that before making a...   Feb 20 2018, 07:34 AM
stownsen914   I agree with your thought to use heavier rear spri...   Feb 20 2018, 09:45 AM
yeahmag   Chris, the bar is set to 3/4 hard, so I only have ...   Feb 20 2018, 12:19 PM
Racer Chris   Stiffer rear springs isn't going to help the r...   Feb 20 2018, 01:35 PM
yeahmag   Yup. Full soft (Koni Yellow). I'm not really h...   Feb 20 2018, 01:37 PM
brant   I'm also wondering if you have a cage in this ...   Feb 20 2018, 02:32 PM
stownsen914   Sorry if I missed it, but what kind of horsepower ...   Feb 20 2018, 02:52 PM
sixaddict   Once Chris speaks ---I listen !   Feb 20 2018, 02:58 PM
yeahmag   (Let me know if you get sick of talking about this...   Feb 20 2018, 03:33 PM
Racer Chris   Is the idea to use the diagonal to hold the oppos...   Feb 20 2018, 04:11 PM
yeahmag   Chris, I'll see if I can "get" that ...   Feb 20 2018, 05:16 PM
Racer Chris   ... Do you have a preferred set up for an aggress...   Feb 20 2018, 07:58 PM
brilliantrot   I thought Aaron's car felt pretty darn good an...   Feb 20 2018, 06:27 PM
Cracker   I haven't seen this...LSD or TBD in the car no...   Feb 22 2018, 10:04 AM
Racer Chris   I haven't seen this...LSD or TBD in the car n...   Feb 22 2018, 10:09 AM
Cracker   One of my race cars has 80 ft lbs torque and has a...   Feb 22 2018, 11:04 AM
yeahmag   I do think an LSD would help this car, just way, w...   Feb 22 2018, 11:49 AM
pcar916   My car is where I like it on a road course, and go...   Feb 23 2018, 06:01 AM
yeahmag   I'm constantly tweaking tire pressures, but we...   Feb 23 2018, 11:45 AM
pcar916   I'm constantly tweaking tire pressures, but w...   Feb 23 2018, 05:45 PM
yeahmag   I may have a line on a 22mm sway bar (Gerold) and ...   Feb 23 2018, 05:52 PM
stownsen914   So I'll throw this out there ... years ago wh...   Feb 25 2018, 09:52 AM
sixnotfour   :driving:   Feb 25 2018, 04:01 PM
sixnotfour   flat 8   Feb 25 2018, 04:02 PM
- Lo-Fi Version Time is now: 4th July 2025 - 01:12 AM
