1.8l Ljet starts fine in cold weather, but not when it's warm? |
Geezer914 |
Feb 25 2018, 02:02 PM
Geezer914 Group: Members Posts: 1,433 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
1975 Ljet 1.8l. The car starts and runs fine in cold weather. When it is warm, the engine cranks and cranks and will not start. Use a little starting fluid, it starts, but unless I keep my foot on the accelerator, it will stall until it warms up. Head temperature sensor???
Geezer914 |
Feb 27 2018, 01:15 PM
It was around 54 degrees yesterday when I checked the sensor. It was 36 this morning and it fired up no problem. Something is preventing the engine from getting enough fuel to start on a warm day.
sfrenck |
Feb 28 2018, 06:59 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
It was around 54 degrees yesterday when I checked the sensor. It was 36 this morning and it fired up no problem. Something is preventing the engine from getting enough fuel to start on a warm day. Or is your Cold Start Valve giving you extra gas on a cold day? I guess I mean maybe you aren't getting enough fuel from your injectors at any outside temperature and your Cold Start Valve makes things work when it is active? I suppose the same thoughts work for too much air (vacuum leak) all the time and the Cold Start Valve is giving you the extra fuel needed. |
Lo-Fi Version | Time is now: 1st June 2024 - 01:39 AM |
