> Left side ignition switch conversion-Alternate Idea, Conversion is completed.
jkb944t
post Mar 22 2017, 11:07 AM
I am considering an alternate plan for a left side ignition switch conversion. My plan is to alter a standard 914-4 steering column to accept a left side 911 ignition switch including the locking feature.
I would remove the right hand ignition switch and possibly fill in the area like some others have done. The other option would be to insert a push button switch instead of the key tumbler and use it to energize a windshield washer pump motor.
I will need to get some dimensions shown on the photo so I know how to modify the standard 914-4 column to accept the 911 ignition switch. It would be very helpful if someone can help with these dimensions.
Jeff B
Rob-O
post Mar 8 2018, 12:56 PM
Would it be easier to just make a harness for the fog switch. Less wires than the emergency flasher, aren’t there?
jkb944t
post Mar 8 2018, 04:06 PM
QUOTE(Rob-O @ Mar 8 2018, 01:56 PM) *
I agree that it would be a lot easier to move the fog light but it just seems like it should be next to the headlight switch.
Jeff B
jkb944t   Left side ignition switch conversion-Alternate Idea   Mar 22 2017, 11:07 AM
SixerJ   Jeff, I should be able to get the dims for you off...   Mar 22 2017, 05:04 PM
jkb944t   Jeff, I should be able to get the dims for you of...   Mar 23 2017, 05:47 AM
SixerJ   Hi Jeff, 1st off apologies for the delay, work and...   Apr 3 2017, 02:32 PM
jkb944t   I have restarted working on this project again thi...   Mar 1 2018, 12:15 PM
gothspeed   Wow! it looks amazing!! it seems like...   Mar 1 2018, 02:20 PM
jkb944t   I made some substantial progress this weekend. I ...   Mar 5 2018, 12:13 PM
Mueller   Nice work! I see more "conversions...   Mar 5 2018, 12:26 PM
raynekat   Curious about the wiring differences between the 9...   Mar 6 2018, 12:01 AM
mepstein   Curious about the wiring differences between the ...   Mar 6 2018, 07:04 AM
jkb944t   Curious about the wiring differences between the ...   Mar 6 2018, 12:15 PM
914forme   That is ingenious work yet lots of hassle, for a k...   Mar 6 2018, 07:28 AM
Larmo63   Something I was planning on taking on in the futur...   Mar 6 2018, 09:40 AM
Larmo63   And.......   Mar 6 2018, 09:41 AM
jkb944t   And....... The part that will be difficult wi...   Mar 6 2018, 12:56 PM
Chris Scott   Jeff, I have already removed my ignition switch fr...   Mar 6 2018, 10:01 AM
jkb944t   The wiring is very simple for the switch except fo...   Mar 7 2018, 06:47 AM
Larmo63   My switch is early 911/912, straight into dash. Th...   Mar 7 2018, 06:54 AM
gothspeed   Nice job doing the metal work for the ignition. Th...   Mar 7 2018, 09:38 AM
mepstein   Nice job doing the metal work for the ignition. T...   Mar 7 2018, 09:55 AM
gothspeed   Nice job doing the metal work for the ignition. ...   Mar 7 2018, 09:59 AM
jkb944t   Getting back to the modification….next step is m...   Mar 7 2018, 11:59 AM
gothspeed   I have two problems to solve before I can move fo...   Mar 7 2018, 12:56 PM
jkb944t   I have two problems to solve before I can move f...   Mar 8 2018, 06:46 AM
Rob-O   Would it be easier to just make a harness for the ...   Mar 8 2018, 12:56 PM
jkb944t   Would it be easier to just make a harness for the...   Mar 8 2018, 04:06 PM
ClayPerrine   I moved my emergency flasher on my six conversion ...   Mar 8 2018, 02:19 PM
jkb944t   I moved my emergency flasher on my six conversion...   Mar 8 2018, 04:10 PM
jkb944t   Below is the modified steering housing next to the...   Mar 8 2018, 04:16 PM
jkb944t   Finished up the ignition switch wiring harness thi...   Mar 9 2018, 07:02 AM
gothspeed   workmanship is looking awesome! I like the cus...   Mar 9 2018, 08:17 AM
jkb944t   Thanks, just a few details to finish. Hopefully Iâ...   Mar 9 2018, 09:35 PM
914werke   This is a great thread! Thank you   Mar 9 2018, 09:38 PM
jkb944t   I finished up the emergency flasher wiring harness...   Mar 12 2018, 11:11 AM
Larmo63   Wow, that looks great. Good info and step by step...   Mar 12 2018, 11:59 AM
sixnotfour   The plastic ones can be done with epoxy, and a fil...   Mar 12 2018, 01:34 PM
jkb944t   The plastic ones can be done with epoxy, and a fi...   Mar 13 2018, 03:45 PM
gothspeed   Amazing results! Thank you for sharing these i...   Mar 12 2018, 10:50 PM
jkb944t   Amazing results! Thank you for sharing these ...   Mar 13 2018, 05:57 AM
gothspeed   jkb944t if possible post pics when you get the fin...   Mar 13 2018, 02:31 PM
jkb944t   The pictures below show the final conversion with ...   Mar 26 2018, 10:44 AM
- Lo-Fi Version Time is now: 12th November 2025 - 08:44 AM
