| 98101 |
Mar 11 2018, 05:49 PM
Michael in Seattle ![]() ![]() Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
Usual rear trunk button has been replaced with a cable release from the cabin to make way for the aftermarket rear reflector. Please note: this is the mechanical CABLE RELEASE, not the electric solenoid that some kits used.
First sunny day in a while. Put the roof in the rear trunk. Never sure I'll be able to get it open again. Now it's time to park. Pulling the cable in the cabin, hear a clicking sound but trunk still seems to be latched. Cannot secure the car. Anyone else had this experience? The reflector sure looks cool, but I'm not sure it's worth this hassle! |
| ndfrigi |
Mar 11 2018, 06:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Usual rear trunk button has been replaced with a cable release from the cabin to make way for the aftermarket rear reflector. First sunny day in a while. Put the roof in the rear trunk. Never sure I'll be able to get it open again. Now it's time to park. Pulling the cable in the cabin, hear a clicking sound but trunk still seems to be latched. Cannot secure the car. Anyone else had this experience? The reflector sure looks cool, but I'm not sure it's worth this hassle! Maybe Try asking someone to press on the button while you push down and up the trunk. |
| Rand |
Mar 11 2018, 06:34 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Maybe Try asking someone to press on the button while you push down and up the trunk. That's a great suggestion. Sometimes the clicker needs some give after it gets weak, so butt weight at the right time with the release can bump it loose. But again... dependent on electrical which WILL fail at some point, so put in a backup after this. |
| 98101 |
Mar 11 2018, 06:38 PM
Maybe Try asking someone to press on the button while you push down and up the trunk. That's a great suggestion. Sometimes the clicker needs some give after it gets weak, so butt weight at the right time with the release can bump it loose. But again... dependent on electrical which WILL fail at some point, so put in a backup after this. Thanks, but this is the cable release version, not the solenoid version. Might still work though, so I’ll round up some help. |
98101 your experience with rear trunk cable Mar 11 2018, 05:49 PM
hockeymutt No clue how to fix this. But one fix to keep it is... Mar 11 2018, 05:56 PM
SO.O.C914er I’ve had this problem before. Try having someone... Mar 11 2018, 06:35 PM
Rand Sorry, thought you had the rear reflector mod with... Mar 11 2018, 06:44 PM
98101
Sorry, thought you had the rear reflector mod wit... Mar 11 2018, 06:51 PM
Rand
Sorry, thought you had the rear reflector mod wi... Mar 11 2018, 07:00 PM
98101
[quote name='98101' post='2588084' date='Mar 11 2... Mar 11 2018, 08:22 PM
wes Works for me no not right but! Push down on yo... Mar 12 2018, 12:23 AM
Steve I had similar issues with the cable and switched t... Mar 12 2018, 12:38 AM
ndfrigi Or you can just drill a hole in the reflector and ... Mar 12 2018, 03:21 AM
rhodyguy The stealth release is a piece of thin SS wire and... Mar 12 2018, 07:34 AM
bdstone914 If all else fails remove both of the white cups in... Mar 12 2018, 07:46 AM
98101
Then install a pull cable like the engine lid has... Mar 12 2018, 10:38 AM
76-914 A few possibilities. Cable has slipped at attach p... Mar 12 2018, 08:00 AM
dr914@autoatlanta.com the solenoid plunger does not go far enough into ... Mar 12 2018, 09:10 AM
98101 UPDATE: Mechanics at Gerber Motorsport were able t... Mar 12 2018, 04:18 PM
KELTY360 Michael - I think when you put the top in the trun... Mar 12 2018, 04:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:24 AM |
