| 98101 |
Mar 11 2018, 05:49 PM
Michael in Seattle ![]() ![]() Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest |
Usual rear trunk button has been replaced with a cable release from the cabin to make way for the aftermarket rear reflector. Please note: this is the mechanical CABLE RELEASE, not the electric solenoid that some kits used.
First sunny day in a while. Put the roof in the rear trunk. Never sure I'll be able to get it open again. Now it's time to park. Pulling the cable in the cabin, hear a clicking sound but trunk still seems to be latched. Cannot secure the car. Anyone else had this experience? The reflector sure looks cool, but I'm not sure it's worth this hassle! |
| 76-914 |
Mar 12 2018, 08:00 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
A few possibilities. Cable has slipped at attach point; Roof is not allowing the trunk to close w/o interference; latch not adjusted properly; and rarely the rear panel (the piece the lock mechanism bolts to) is pushed in slightly (1/8" is enough) and not allowing the cam to rotate. It's the round piece with a short pin that releases the latch when rotated. (IMG:style_emoticons/default/beerchug.gif) You will not know if it is this until the trunk is opened and you can look at the lock as the cable (or key in standard configuration) is used. (IMG:style_emoticons/default/beerchug.gif)
98101 your experience with rear trunk cable Mar 11 2018, 05:49 PM
hockeymutt No clue how to fix this. But one fix to keep it is... Mar 11 2018, 05:56 PM
ndfrigi
Usual rear trunk button has been replaced with a ... Mar 11 2018, 06:27 PM
Rand
Maybe Try asking someone to press on the button w... Mar 11 2018, 06:34 PM
98101
Maybe Try asking someone to press on the button ... Mar 11 2018, 06:38 PM
SO.O.C914er I’ve had this problem before. Try having someone... Mar 11 2018, 06:35 PM
Rand Sorry, thought you had the rear reflector mod with... Mar 11 2018, 06:44 PM
98101
Sorry, thought you had the rear reflector mod wit... Mar 11 2018, 06:51 PM
Rand
Sorry, thought you had the rear reflector mod wi... Mar 11 2018, 07:00 PM
98101
[quote name='98101' post='2588084' date='Mar 11 2... Mar 11 2018, 08:22 PM
wes Works for me no not right but! Push down on yo... Mar 12 2018, 12:23 AM
Steve I had similar issues with the cable and switched t... Mar 12 2018, 12:38 AM
ndfrigi Or you can just drill a hole in the reflector and ... Mar 12 2018, 03:21 AM
rhodyguy The stealth release is a piece of thin SS wire and... Mar 12 2018, 07:34 AM
bdstone914 If all else fails remove both of the white cups in... Mar 12 2018, 07:46 AM
98101
Then install a pull cable like the engine lid has... Mar 12 2018, 10:38 AM
dr914@autoatlanta.com the solenoid plunger does not go far enough into ... Mar 12 2018, 09:10 AM
98101 UPDATE: Mechanics at Gerber Motorsport were able t... Mar 12 2018, 04:18 PM
KELTY360 Michael - I think when you put the top in the trun... Mar 12 2018, 04:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:38 PM |
