| bixs |
Dec 10 2017, 04:37 PM
Newbie ![]() Group: Members Posts: 9 Joined: 11-May 11 From: Irvine, CA Member No.: 13,061 Region Association: None |
Everything came off a 1970 914 that was likely pieced together with parts. I no longer have the car so I'm just trying to clean out my parts surplus.
*Update: 3/10/2018 ADDED a bunch of smaller items* 1. Fuel tank, SOLD 2. Seat bracket SOLD 3. Seats SOLD 4. fuel cap SOLD 5. fuel filler neck SOLD 6. Fuel tank straps SOLD 7. Cunifer brake lines, (Product page says: Porsche 914 all except 75-76) SOLD ---------------------------------------------------------------------- Service kit from AutoAtlanta (was $100) Asking $60 1. Oil filter 2. Fuel filter 3. Continental alternator belt 4. Bosch spark plugs 5. Bosch contacts 6. Bosch rotor 7. Bosch distributor cap 8. o ring for distributor 9. Ignition condensor 10. 2 cork valve cover gaskets ---------------------------------------------------------------------- Victor Reinz Fuel Injector base seals and tip seals, $1 for 8 total seals SOLD ---------------------------------------------------------------------- Genuine Porsche Tapered Fuel Hose for Connection at Fuel filter, 70-74 1.7/1.8/2.0 SOLD ---------------------------------------------------------------------- VDO Fuel Tank sending unit gasket 1.7/1.8/2.0 (1970-76), SOLD ---------------------------------------------------------------------- Victor Reinz Intake Manifold gaskets 1.7/1.8 1970-1975, $7 for 2 gaskets ---------------------------------------------------------------------- Stainless Steel Tunnel Fuel Line Set (one 8mm and one 9.5mm), 914 (1970-74), SOLD ---------------------------------------------------------------------- Stainless Steel Engine Compartment Fuel Line Set (NOTE: 1970-74 cars also use tapered fuel hose 914-356-525-00-M100), 914 (1970-76), SOLD ---------------------------------------------------------------------- Victor Reinz cork valve cover gaskets, $5 for 2 ---------------------------------------------------------------------- Fuse Kit - 911, 912, 930, 924, 928 1978-84, 944 1982-85.5 914 Fuse Assortment SOLD Bulb Kit - Assortment $3 |
| cooper951 |
Mar 13 2018, 10:38 AM
Member ![]() ![]() Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
Do you have the back pad?
bixs FS: Fuel tank, seats, brake lines Dec 10 2017, 04:37 PM
bdstone914 What does that tank look like inside? Outside look... Dec 11 2017, 05:37 AM
bixs :bump: Bump! I included two pictures of the i... Feb 24 2018, 05:22 PM
bixs bump! Mar 10 2018, 12:29 PM
Psw1811 I would like the brake lines if you would consider... Mar 10 2018, 03:54 PM
bixs Added a lot of smaller sparts + fuel lines
-----... Mar 10 2018, 06:25 PM
danoswork I will take the fuel filler neck. email danoswork@... Mar 11 2018, 10:50 AM
koozy Interested in the fuses Mar 11 2018, 11:04 AM
kahluver PM Sent - I'll buy all of the fuel tank parts,... Mar 11 2018, 09:05 PM
type47fan PM sent Mar 12 2018, 12:11 PM
dakotaewing Based on the ad, looks like you have 2 stainless f... Mar 12 2018, 10:00 PM
bixs
I do, I'm selling... Mar 13 2018, 12:03 PM
bixs I've added some PENDING to the original post, ... Mar 13 2018, 12:04 PM
Jonathan Livesay I'll take the seats. Sending PM Mar 13 2018, 12:30 PM
Mike D. second on the seat set. pm sent
thanks Mar 14 2018, 12:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd September 2026 - 08:15 PM |
