Recurve / rebuild SC dizzy, for carburated engine |
rgalla9146 |
Mar 13 2018, 08:24 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Looking for anyone who has had good results with a distributor re-curve rebuild.
The engine is a stock 1981 911 SC converted to carbs Of course Jerry Woods is well known.....anyone else ? |
Justinp71 |
Mar 14 2018, 11:02 AM
Senior Member Group: Members Posts: 1,584 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
Looking for anyone who has had good results with a distributor re-curve rebuild. The engine is a stock 1981 911 SC converted to carbs Of course Jerry Woods is well known.....anyone else ? Btw, this motor is exactly what I started with. I ran it with DC19 cams, headers, re-curved dizzy and webber IDA 40's. I can probably find my old carb settings if you want. It was a phenomenal motor. I was at thunderhill with a stock '81 911 on slicks, I blew his doors off and lapped him with in the 20 minute run session. I know the 914 is lighter, but there was no comparison between cars. The 911 owner was stunned. (IMG:style_emoticons/default/blink.gif) . Totally got me hooked (IMG:style_emoticons/default/smile.gif). Also the DC19 cam can be run with stock FI pistons- http://www.drcamshafts.com/. I think it really helped the motor kick in along with the re-curved dizzy. |
rgalla9146 |
Mar 14 2018, 10:11 PM
Looking for anyone who has had good results with a distributor re-curve rebuild. The engine is a stock 1981 911 SC converted to carbs Of course Jerry Woods is well known.....anyone else ? Btw, this motor is exactly what I started with. I ran it with DC19 cams, headers, re-curved dizzy and webber IDA 40's. I can probably find my old carb settings if you want. It was a phenomenal motor. I was at thunderhill with a stock '81 911 on slicks, I blew his doors off and lapped him with in the 20 minute run session. I know the 914 is lighter, but there was no comparison between cars. The 911 owner was stunned. (IMG:style_emoticons/default/blink.gif) . Totally got me hooked (IMG:style_emoticons/default/smile.gif). Also the DC19 cam can be run with stock FI pistons- http://www.drcamshafts.com/. I think it really helped the motor kick in along with the re-curved dizzy. Excellent. I shouldn't be concerned about having the smaller intake ports ? Carb specifics would be greatly appreciated Your pistons were standard SC ? Any head work ? TIA Rory |
Justinp71 |
Mar 14 2018, 11:55 PM
Looking for anyone who has had good results with a distributor re-curve rebuild. The engine is a stock 1981 911 SC converted to carbs Of course Jerry Woods is well known.....anyone else ? Btw, this motor is exactly what I started with. I ran it with DC19 cams, headers, re-curved dizzy and webber IDA 40's. I can probably find my old carb settings if you want. It was a phenomenal motor. I was at thunderhill with a stock '81 911 on slicks, I blew his doors off and lapped him with in the 20 minute run session. I know the 914 is lighter, but there was no comparison between cars. The 911 owner was stunned. (IMG:style_emoticons/default/blink.gif) . Totally got me hooked (IMG:style_emoticons/default/smile.gif). Also the DC19 cam can be run with stock FI pistons- http://www.drcamshafts.com/. I think it really helped the motor kick in along with the re-curved dizzy. Excellent. I shouldn't be concerned about having the smaller intake ports ? Carb specifics would be greatly appreciated Your pistons were standard SC ? Any head work ? TIA Rory The smaller intake ports give better low end response. The dc19 is not a huge duration high hp cam, so I think it’s still a good match. How much hp is there to gain over a stock or 964 cam grind is hard to tell, dc racing might know bettter. I had stock 81 heads and stock pistons, motor long block was all stock 81 3.0 besides the cams. The next level up would be larger head ports, dc40 cams and je pistons. But that’s a good chunk of change, should give another ~30hp. I would do that all at once, I don’t think head work willl matter too much without dc40 or larger cams, but I could be wrong. And to run those cams you need new pistons. One thing that is nice with dc40 cams they are designed for carbs ( I think better lobe center) so they react faster to the carbs. I will dig up and send you my old carb settings. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 10th June 2024 - 09:20 PM |
