gas tank pipe sealing |
JFG |
Mar 15 2018, 01:42 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I lost the tear down pics so i have no images of how it came apart.
Can someone help me with the way to seal the outlet / return pipe that screw onto the bottom of the tank. I have aluminium washers and fibre washers. I've tried with both, the fibres leak badly. They were squashed between the tank and the round collar fixed to the small steel pipe tail. I've tried using just an aluminium washer in the same position as above but still a slight leak. As the retaining nuts are a soft alloy i can't tighten them anymore. Just in case i do ruin them trying to seal them, does anyone know the correct thread size of the outlets on the tank? |
JFG |
Mar 15 2018, 02:33 PM
The catalogue shows outlet has 1 aluminium washer
The return shows 1 fibre washer only so i'm not confident this is correct. I think as detailed above is correct even though one is m10 & one is m8. Ideally i would like to fit something like a copper pipe/union, maybe from something like a rally parts provider or similar but i need to know the thread size. |
Lo-Fi Version | Time is now: 1st June 2024 - 07:10 AM |
