Dual Carb Problem need help |
Cazz |
Mar 17 2018, 12:38 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
Any carb specialists out there? I need help with a carb problem.
-1974 2.0 with dual weber carbs -The car is spitting and popping out the carb on cylinders 1&2and also backfiring alittle. I've rebuilt the carbs and pulled this carb off again completely taking it apart and checking with no obvious issues found -With the car idling when I put my hand over each barrel on this carb there is no suction at all on my hand. The idle doesn't drop at all. Doesn't respond to any adjustments on the fuel/air mixture screws. -The carb is injecting fuel streams when I open the linkage by hand -On the carb on the opposite side when I put my hand over each velocity stack it really pulls air really hard on my hand and the car will bog down and shut off as it should. -I have new intake gaskets an new carb base gaskets installed. I sprayed carb cleaner around the base of the carb and also at the head with no change in idle. Any ideas? Is this car basically running on 2 cylinders? -On the opposite carb on cylinders |
MarkV |
Mar 17 2018, 02:45 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Sounds like they are way out of sync. Find a good carb sync set of instructions and follow it exactly not skipping any steps.
Try this one: http://www.aircooled.net/synchronize-dual-...arburetors-103/ |
porschetub |
Mar 17 2018, 03:03 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sounds like they are way out of sync. Find a good carb sync set of instructions and follow it exactly not skipping any steps. Try this one: http://www.aircooled.net/synchronize-dual-...arburetors-103/ (IMG:style_emoticons/default/agree.gif) ,really points to that,maybe the motor needs a good tune-up also,pointless tuning carbs until done. |
Lo-Fi Version | Time is now: 5th June 2024 - 08:56 AM |
