| mb911 |
Mar 10 2018, 03:41 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,783 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
| mb911 |
Mar 19 2018, 04:32 PM
Well yesterday went to the zoo with the younger kids so my 17 year decided to pull the reference and speed sensors and broke them.. Oh well thats how he will learn and then took the injectors out so we could soak them in seafoam.. Also proceeded to pull the tank metal threaded bung out with the tank screen. Now I need to find a bonding agent for plastic to metal that is impervious to gas.. Any suggestions?
Oh also the lug nuts decenegrated on 2 lugs and not sure how to deal with that one.. Just yet..its fun none the less. Also considering buying a lift. This will free up some space. |
| theer |
Mar 19 2018, 09:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 692 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States
Well yesterday went to the zoo with the younger kids so my 17 year decided to pull the reference and speed sensors and broke them.. Oh well thats how he will learn and then took the injectors out so we could soak them in seafoam.. Also proceeded to pull the tank metal threaded bung out with the tank screen. Now I need to find a bonding agent for plastic to metal that is impervious to gas.. Any suggestions? Oh also the lug nuts decenegrated on 2 lugs and not sure how to deal with that one.. Just yet..its fun none the less. Also considering buying a lift. This will free up some space. In reverse order: Lift: Do it. 4-post, 2-post, mid rise - each have their merits. All help immensely. Lug nuts: the stock lugs are super light weight alloy, but start flaking apart after too many years of neglect. Use a smaller size 6-point socket and bash it on then carefully, slowly loosen. Do this by hand, no air guns! Then go buy the steel replacements for $2/pc. Gas tank: your FLAPS sells gas-tank specific epoxy. But you may want to buy a complete unit from the 944 world out there. Speed and crank sensors: these can be tricky (and expensive). They look identical, but are not interchangeable. Also, they need to be installed with proper spacing, etc. I might have a set, if you are interested. On the fuel pump: try powering directly to see if it works. Mine was jammed, but I was able to get it going with carb cleaner and running it backward & forward. Works fine now. If the fuel pump works, try a new DME relay. I might have one of these, too. Good luck! Tom PS: my daughter’s first car was a POS Reatta, my son’s a POS 944. Reatta was cool & unique, but an electronics nightmare. 944 is a better choice if you have to work on it. |
| mb911 |
Mar 20 2018, 05:00 AM
Well yesterday went to the zoo with the younger kids so my 17 year decided to pull the reference and speed sensors and broke them.. Oh well thats how he will learn and then took the injectors out so we could soak them in seafoam.. Also proceeded to pull the tank metal threaded bung out with the tank screen. Now I need to find a bonding agent for plastic to metal that is impervious to gas.. Any suggestions? Oh also the lug nuts decenegrated on 2 lugs and not sure how to deal with that one.. Just yet..its fun none the less. Also considering buying a lift. This will free up some space. In reverse order: Lift: Do it. 4-post, 2-post, mid rise - each have their merits. All help immensely. Lug nuts: the stock lugs are super light weight alloy, but start flaking apart after too many years of neglect. Use a smaller size 6-point socket and bash it on then carefully, slowly loosen. Do this by hand, no air guns! Then go buy the steel replacements for $2/pc. Gas tank: your FLAPS sells gas-tank specific epoxy. But you may want to buy a complete unit from the 944 world out there. Speed and crank sensors: these can be tricky (and expensive). They look identical, but are not interchangeable. Also, they need to be installed with proper spacing, etc. I might have a set, if you are interested. On the fuel pump: try powering directly to see if it works. Mine was jammed, but I was able to get it going with carb cleaner and running it backward & forward. Works fine now. If the fuel pump works, try a new DME relay. I might have one of these, too. Good luck! Tom PS: my daughter’s first car was a POS Reatta, my son’s a POS 944. Reatta was cool & unique, but an electronics nightmare. 944 is a better choice if you have to work on it. Was gonna order the sensors today so let me know if you do have some spares.. Thanks |
mb911 Sons 1st porsche. Mar 10 2018, 03:41 PM
Tom_T If it runs for $600 Ben, then it's a stea... Mar 10 2018, 03:55 PM
mb911
If it runs for $600 Ben, then it's a ste... Mar 10 2018, 04:15 PM
bretth Nice. Always loved the phone dials on the 944. Mar 10 2018, 03:55 PM
914Sixer 88 is a good year for 944's. $600 is eve... Mar 10 2018, 04:02 PM
dr914@autoatlanta.com they drive great and are a real bargain these days... Mar 10 2018, 04:24 PM
Coondog
they drive great and are a real bargain these day... Mar 11 2018, 06:59 AM
iwanta914-6 Since my dad's first Porsche was a 1987 944 Tu... Mar 10 2018, 04:26 PM
poorsche914 My son's first car was an '83 944 inherite... Mar 10 2018, 05:06 PM
billh1963
Since my dad's first Porsche was a 1987 944 T... Mar 10 2018, 08:10 PM
cal44 I've watch 944's time and time again out c... Mar 10 2018, 05:04 PM
Dion Congrats to your son! I’m actually looking ... Mar 10 2018, 05:34 PM
mb911 Might drain gas tomorrow and throw a battery in it... Mar 10 2018, 06:17 PM
mepstein Len Commings / Boxter GT, has a crapload of 944 pa... Mar 10 2018, 08:22 PM
hockeymutt Always been on the hunt for 944 turbo. My dad had ... Mar 10 2018, 08:42 PM
theer My son’s first car was/is an $800 ‘86 944... Mar 10 2018, 11:41 PM
Edward Blume :trophy: Congratulations!
Time to rent 16 Can... Mar 11 2018, 06:54 AM
mb911
Time to rent 16 Ca... Mar 11 2018, 07:17 AM
Edward Blume
[quote name='Edward Blume' post='2587898' date='M... Mar 11 2018, 07:26 AM
Edward Blume
[quote name='mb911' post='2587902' date='Mar 11 2... Mar 11 2018, 07:31 AM
Edward Blume
[quote name='mb911' post='2587902' date='Mar 11 ... Mar 11 2018, 07:36 AM
ConeDodger That was Nicho’s first car too. His is an 85.2 i... Mar 11 2018, 08:35 AM
gandalf_025 The closest thing to a 600.00 Porsche would be
a ... Mar 11 2018, 09:26 AM
73-914
a... Apr 22 2018, 06:30 PM
mb911
... Apr 23 2018, 05:12 AM
JRust I picked up a 944 turbo that had been in a wreck. ... Mar 11 2018, 09:34 AM
mb911
I picked up a 944 turbo that had been in a wreck.... Mar 11 2018, 10:08 AM
GeorgeRud Looks like a great deal and nice to see your boy c... Mar 11 2018, 10:52 AM
mb911
Looks like a great deal and nice to see your boy ... Mar 11 2018, 11:06 AM
914-300Hemi Congrats on a great find and first Porsche. Mar 11 2018, 11:14 AM
mb911 Minor update is replaced fuel line from tank to fu... Mar 11 2018, 02:38 PM
porschetub
Minor update is replaced fuel line from tank to f... Mar 20 2018, 12:36 PM
mb911
Minor update is replaced fuel line from tank to ... Mar 20 2018, 04:10 PM
porschetub
[quote name='porschetub' post='2590752' date='Mar... Mar 21 2018, 01:23 PM
Mueller Cool score, if time, money and space ever permits ... Mar 11 2018, 03:27 PM
theer
[quote name='theer' post='2590561' date='Mar 19 2... Mar 20 2018, 06:52 AM
GeorgeRud It’s always good to catch Porsche fever at a you... Mar 19 2018, 08:31 PM
JmuRiz
It’s always good to catch Porsche fever at a yo... Mar 20 2018, 07:52 AM
mb911 Did a little powdercoat for my son. The badge was ... Mar 20 2018, 07:51 AM
mb911
Powdercoat this as well.. Inspirational I hope ... Mar 20 2018, 10:58 AM
JmuRiz I like that black badge, pretty cool...kind of GTS... Mar 20 2018, 12:08 PM
mb911 Unfortunately now a bit larger of a problem the fe... Mar 21 2018, 07:53 AM
jd74914 Not sure exactly what I'm looking at, but can ... Mar 21 2018, 10:30 AM
mb911
Not sure exactly what I'm looking at, but can... Mar 21 2018, 11:41 AM
jesse7flying You might ask over on the Bird 944 forum. Lots of... Mar 21 2018, 12:44 PM
theer '88 definitely has the plastic tank (all ... Mar 21 2018, 01:43 PM
theer Ok- I lied when I said the sensors are not interch... Mar 23 2018, 04:29 PM
mb911 Tom,
Thanks yes I would be interested in the sens... Mar 23 2018, 07:46 PM
914forme Ben,
This is the guy I get my 944 donor parts fro... Mar 24 2018, 08:53 AM
mb911
Ben,
This is the guy I get my 944 donor parts fr... Mar 24 2018, 09:51 AM
mb911 Yeah car started today.. Needs a fuel pump as well... Mar 25 2018, 02:21 PM
mb911 Tank and fuel pump showed up yesterday from plyham... Apr 5 2018, 06:01 AM
mb911 Car ran very well today off of the new used fuel p... Apr 22 2018, 06:04 PM
mb911 Update,
Transaxle back in after replacing the gas... Jun 2 2018, 07:56 AM
mb911 Today we drove it down our non public road.. Drive... Jun 3 2018, 01:44 PM
AZBanks If you need 944 parts, check with Lart(Lois).
htt... Jun 7 2018, 08:56 PM
mb911
ht... Jun 9 2018, 07:22 AM
mb911 Wheels done well 2 of them. Working on timing belt... Jun 14 2018, 05:55 AM
mb911 Working on multiple cars today.. I am tired and so... Jun 23 2018, 07:00 PM
mb911 RE: Sons 1st porsche. Jun 23 2018, 07:00 PM
Dion Wheels look cool Ben. We are in the same situatio... Jun 23 2018, 07:59 PM
mb911
Wheels look cool Ben. We are in the same situati... Jun 24 2018, 05:01 AM
mb911 Went to baseball with our younger son and came hom... Jul 15 2018, 08:31 AM
mb911 He sanded everything and I showed him today how to... Jul 22 2018, 02:22 PM
mb911 Painted today.. Turned out pretty nice.. Did it ou... Sep 8 2018, 12:42 PM
mb911 Front half is painted Sep 21 2018, 02:14 PM
mb911 Dragged him out to get some parts off the ground a... Oct 6 2018, 10:22 AM
worn It is a pretty nice looking car now. He is doing ... Oct 6 2018, 11:27 AM
GeorgeRud It’s looking great! Luckily boy to have a d... Oct 6 2018, 10:59 AM
mb911 Thanks.. Still gotta paint the back half of the ca... Oct 6 2018, 05:15 PM
914Sixer I understand the story about the attention span th... Oct 6 2018, 07:00 PM
bbrock
Remember when we had dial up computer connection?... Oct 6 2018, 08:12 PM
mb911
I understand the story about the attention span t... Oct 7 2018, 06:14 AM
I understand the story about the attention span ... Nov 4 2018, 11:37 AM
mb911 Finally spent some time on this.. 2 cars torn apar... Nov 4 2018, 09:34 AM
alfadoc Been daily driving a 944 for almost 15 years, firs... Nov 11 2018, 11:42 AM
dan10101 Awesome, Father and Son Porsches.
Brings back m... Nov 12 2018, 07:31 PM
mb911 Painted today.. Dec 24 2018, 03:56 PM
TravisNeff Sweet! I need to get over my phobia about pain... Dec 24 2018, 04:26 PM
mb911 Here are some more money shots.. Now to buff.. Dec 27 2018, 04:07 PM
mb911 Picture of it getting closer to completion. Jan 13 2019, 09:50 AM
mepstein So is every kid getting a Porsche? :poke: :lol: Jan 13 2019, 10:26 AM
mb911 Roof replacement painted this weekend. Feb 10 2019, 07:53 PM
porschetub Ditch the pod filter they loose power with them...... Feb 10 2019, 11:59 PM
mb911
Ditch the pod filter they loose power with them..... Feb 11 2019, 05:52 AM
Ditch the pod filter they loose power with them.... Feb 11 2019, 08:07 AM
Mayne Looks very nice. How have you felt about taping of... Feb 11 2019, 06:53 AM
mb911 @Mayne . Sorry for the delay responding. I felt f... Apr 7 2019, 12:11 PM
Dion Looks nice! I’m sure he couldn’t wait to g... Apr 7 2019, 12:17 PM
mb911 @Dion that is for sure.. Now all the little thing... Apr 7 2019, 12:53 PM
mb911 All the little projects on this car has really tak... Apr 21 2019, 07:38 PM
All the little projects on this car has really ta... Apr 21 2019, 09:44 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th June 2026 - 06:01 PM |
