Fuel, Fuel Pump/hoses |
Chip |
Mar 25 2018, 10:51 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Hi everyone! My 1.7 sat for over 30 years. Need to drain tank and install new pump, lines, filter. Anyone know what size lines (braided) come out of the tank? Fuel pump has been moved to front. Also need a good fuel pump. Original Bosch is over $600.
Thanks! Attached image(s) |
mgphoto |
Apr 7 2018, 11:37 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Do you know for sure the fuel pump is bad?
Most times you can run it backwards in a bucket of gas, to clean it out, be careful of sparks do it outside and have a fire extinguisher ready. |
Chip |
Apr 7 2018, 07:22 PM
Do you know for sure the fuel pump is bad? Most times you can run it backwards in a bucket of gas, to clean it out, be careful of sparks do it outside and have a fire extinguisher ready. The pump could be good. The "R" port was completely blocked with black, solid gunk. Can you please explain how I can clean it & check it out? Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 08:23 PM |
