mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,609 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
mb911 |
Updates
There seems to be some of the same questions that pop up when people go to install these. 1st is what type of nuts should be used for installation? You should use the same setup as a 911 with barrel nuts in the locations with the pass through holes. The attached photo shows what they are. Next what oil lines should you use? Typically stock setup is very efficient but a stock -6 cooler has a bracket that can interfere with the heat exchanger so note that. Eric from Pmb is the only one to my knowledge that has run into this but should be noted. Price wise currently they are $1950 for 914world folks. I can hold that price for sure for the next 4 sets but after my current stainless inventory is used up then we will be affected by the current steel price surge.. This is for both for 1.5" and 1.625 .. |
Lo-Fi Version | Time is now: 11th July 2025 - 04:10 PM |
