911 Valve Adjusters, Starting Point Before Geometry Setting |
pilothyer |
Apr 9 2018, 12:01 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
When using 911 Valve Adjusters, with the early rockers (modified of course) what is the starting point on the adjusters. How much do you screw them in to the rockers before you start the valve train geometry procedure. I would imagine you need to have enough threads in either direction for future valve adjustments, but how much ? Thanks for your support, I am at this critical stage on my engine now .
TheCabinetmaker |
Apr 9 2018, 01:47 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Do you have an adjustable pushrod and dial indicator?
pilothyer |
Apr 9 2018, 03:15 PM
Do you have an adjustable pushrod and dial indicator? Yes I have both and fully understand how to use them. My question is before I start the procedure, how much room should be left for future adjustment if the valve adjuster ever gets too tight (seat wear, valve wear, etc.) |
Lo-Fi Version | Time is now: 16th June 2024 - 06:19 AM |
