Fuel, Fuel Pump/hoses |
Chip |
Mar 25 2018, 10:51 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Hi everyone! My 1.7 sat for over 30 years. Need to drain tank and install new pump, lines, filter. Anyone know what size lines (braided) come out of the tank? Fuel pump has been moved to front. Also need a good fuel pump. Original Bosch is over $600.
Thanks! Attached image(s) |
mgphoto |
Apr 9 2018, 01:39 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
OK this is not for the faint of heart nor should it be done in a haphazard fashion.
Plan your problems, (what if I knock over the bucket?) and so on. Be ready. Have a fire extinguisher, for combustible liquids like gasoline, a good one, close by. Fill a plastic bucket with just enough gasoline to cover the fuel pump. Do this someplace that is safely away from structures and combustible materials. Rig up two wires about 8 to 10 feet long, one end connect crimp on connectors to accept the pumps terminals. The other end use a battery clamp such as the items listed below (no affiliation) https://www.globalindustrial.com/p/electric...BCABEgLPj_D_BwE[/url] Try to remove as much gunk as possible, don't damage anything. After connecting the wires to the pump ONLY, place it in the gasoline, a full charged car battery works best for this. Place the fire extinguisher between the battery and the bucket, connect the wires to the battery terminals for 15 seconds, than reverse the polarity. Do this for a few minutes, keep reversing the polarity, soon enough the pump should clear. Now a days fuel pumps are inside the fuel tank, ours are sealed just as the newest ones are, so just be careful, use your head. If this doesn't work than you will need to get this one rebuilt or swap it for a rebuilt. Good luck and be careful! |
Chip |
Apr 10 2018, 11:20 AM
OK this is not for the faint of heart nor should it be done in a haphazard fashion. Plan your problems, (what if I knock over the bucket?) and so on. Be ready. Have a fire extinguisher, for combustible liquids like gasoline, a good one, close by. Fill a plastic bucket with just enough gasoline to cover the fuel pump. Do this someplace that is safely away from structures and combustible materials. Rig up two wires about 8 to 10 feet long, one end connect crimp on connectors to accept the pumps terminals. The other end use a battery clamp such as the items listed below (no affiliation) https://www.globalindustrial.com/p/electric...BCABEgLPj_D_BwE[/url] Try to remove as much gunk as possible, don't damage anything. After connecting the wires to the pump ONLY, place it in the gasoline, a full charged car battery works best for this. Place the fire extinguisher between the battery and the bucket, connect the wires to the battery terminals for 15 seconds, than reverse the polarity. Do this for a few minutes, keep reversing the polarity, soon enough the pump should clear. Now a days fuel pumps are inside the fuel tank, ours are sealed just as the newest ones are, so just be careful, use your head. If this doesn't work than you will need to get this one rebuilt or swap it for a rebuilt. Good luck and be careful! Can't wait to try this. Thank you very much. Will take all the precautions. Perhaps the local fire dept. will allow me to do it in their parking bay? (Kidding). |
Chip |
Apr 16 2018, 02:42 PM
OK this is not for the faint of heart nor should it be done in a haphazard fashion. Plan your problems, (what if I knock over the bucket?) and so on. Be ready. Have a fire extinguisher, for combustible liquids like gasoline, a good one, close by. Fill a plastic bucket with just enough gasoline to cover the fuel pump. Do this someplace that is safely away from structures and combustible materials. Rig up two wires about 8 to 10 feet long, one end connect crimp on connectors to accept the pumps terminals. The other end use a battery clamp such as the items listed below (no affiliation) https://www.globalindustrial.com/p/electric...BCABEgLPj_D_BwE[/url] Try to remove as much gunk as possible, don't damage anything. After connecting the wires to the pump ONLY, place it in the gasoline, a full charged car battery works best for this. Place the fire extinguisher between the battery and the bucket, connect the wires to the battery terminals for 15 seconds, than reverse the polarity. Do this for a few minutes, keep reversing the polarity, soon enough the pump should clear. Now a days fuel pumps are inside the fuel tank, ours are sealed just as the newest ones are, so just be careful, use your head. If this doesn't work than you will need to get this one rebuilt or swap it for a rebuilt. Good luck and be careful! Can't wait to try this. Thank you very much. Will take all the precautions. Perhaps the local fire dept. will allow me to do it in their parking bay? (Kidding). Dear mgphoto: I tried the backflush w/gas method, and after a few shots, the pump began to hum, but then it slows to kind of a chug, chug. When first connected in the right way, it buzzes, then slows. What should it sound like when it is clear?A lot of gunk came out of it. I think it's working! Thank you. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 08:05 PM |
