Fuel, Fuel Pump/hoses |
Chip |
Mar 25 2018, 10:51 PM
Member Group: Members Posts: 125 Joined: 1-April 17 From: Brigham City, UT Member No.: 20,986 Region Association: Intermountain Region |
Hi everyone! My 1.7 sat for over 30 years. Need to drain tank and install new pump, lines, filter. Anyone know what size lines (braided) come out of the tank? Fuel pump has been moved to front. Also need a good fuel pump. Original Bosch is over $600.
Thanks! Attached image(s) |
TheCabinetmaker |
Apr 10 2018, 11:46 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Might try replying to a quote outside the quote box [ ].
Hard to find your reply inside the box. |
Chip |
Apr 16 2018, 02:44 PM
mgphoto |
Apr 17 2018, 05:04 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Might try replying to a quote outside the quote box [ ]. Hard to find your reply inside the box. Thanks. How do I do this? This site is hard for me to learn. There is no "send" button either. This site, as do all websites, uses coding to produce pages for viewing, they are not that difficult to decode. Also anything you post you can edited, just keep that in mind. As for the pump, you may not be out of the woods yet, the pump needs to supply 28 PSI of constant pressure to be functional. As for the sound, it is a sort of a hum, it is noticeable when the key is turned from off to on before turning the key to start. The pump will run for 2 seconds to pressurize the fuel ring, than shut off if the engine is not started. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:25 AM |
