| sjhenry1075 |
Apr 18 2018, 09:21 AM
Member ![]() ![]() Group: Members Posts: 270 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States
So I have a dumb question, but as my wife (who is a teacher) always says, the only dumb question is the question not asked so here goes..
I recently replaced the fuel lines in my 71 with stainless and new braided hose in the engine compartment. My question is, the lines that I purchased from Pelican, the smaller ones, which I believe would be the return lines, would not fit over any of the fittings so I just used the larger line. Does it matter if I use the larger braided hose for both supply and return? Thank you in advance for being patient and providing answers to my questions.. |
| Amphicar770 |
Apr 18 2018, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
Should be fine. The bigger concern should be if the braided fuel line is E85 compatible. Those old school rubber fuel hoses do not like modern gasoline.
| sjhenry1075 |
Apr 18 2018, 09:36 AM
Should be fine. The bigger concern should be if the braided fuel line is E85 compatible. Those old school rubber fuel hoses do not like modern gasoline. That's a good thought and something I never considered. How do I know if the new lines are E85 compatible? |
| Amphicar770 |
Apr 18 2018, 09:54 AM
Should be fine. The bigger concern should be if the braided fuel line is E85 compatible. Those old school rubber fuel hoses do not like modern gasoline. That's a good thought and something I never considered. How do I know if the new lines are E85 compatible? If it was inexpensive it is not compatible. Should be marked 30R9 or higher http://ww2.gates.com/europe/brochure.cfm?b...cation_id=19079 http://www.914world.com/bbs2/index.php?sho...p;#entry2600523 |
sjhenry1075 Dumb Question Apr 18 2018, 09:21 AM
76-914 Won't matter unless you get them crossed. :be... Apr 18 2018, 09:25 AM
Won't matter unless you get them crossed. :b... Apr 18 2018, 09:34 AM
sjhenry1075
Won't matter unless you get them crossed. :... Apr 18 2018, 09:37 AM
The Cabinetmaker I am unaware of any ethanol rated braided line. I ... Apr 18 2018, 01:42 PM
sjhenry1075
I am unaware of any ethanol rated braided line. I... Apr 19 2018, 01:10 PM
Jonathan Livesay
I am unaware of any ethanol rated braided line. I... Apr 19 2018, 01:28 PM
Chris914n6 Depending on year, it's either 2 same size lin... Apr 18 2018, 03:11 PM
jcd914 I don't know the rating of the fuel lines you ... Apr 19 2018, 01:24 PM
sjhenry1075
I don't know the rating of the fuel lines you... Apr 19 2018, 01:35 PM
sjhenry1075 Well you were right, the braided lines seeped fuel... Jul 1 2019, 11:08 AM
ChrisFoley Tangerine Racing Products Jul 1 2019, 11:20 AM
jcd914 :agree: Chris has everything you need including in... Jul 1 2019, 12:41 PM
Mark Henry
:agree: Chris has everything you need including i... Jul 1 2019, 01:05 PM
bbrock
[quote name='jcd914' post='2726958' date='Jul 1 2... Jul 1 2019, 10:41 PM
Mark Henry
[quote name='jcd914' post='2726958' date='Jul 1 ... Jul 3 2019, 12:45 PM
bbrock
[quote name='bbrock' post='2727095' date='Jul 2 2... Jul 3 2019, 03:08 PM
JawjaPorsche Contact Tangerine Racing. Explain what you have a... Jul 1 2019, 01:53 PM
JeffBowlsby 7mm ID for the engine bay fuel hose. The original... Jul 1 2019, 02:07 PM
ChrisFoley
7mm ID for the engine bay fuel hose. The origina... Jul 1 2019, 02:55 PM
VaccaRabite Fires suck. Get that braided crap off your car. ... Jul 1 2019, 02:36 PM
sjhenry1075 Thank you for your replies everyone. I will be rem... Jul 3 2019, 09:25 AM
ChrisFoley
Does it matter if I use the larger [braided] hos... Jul 3 2019, 10:11 AM
sjhenry1075
Does it matter if I use the larger [braided] ho... Jul 3 2019, 10:28 AM
ChrisFoley Ships today.
:) Jul 3 2019, 10:32 AM
sjhenry1075
Ships today.
Thank you Chris! Jul 3 2019, 10:51 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:25 PM |
