Removing broken bolt(s) from trailing arm mounts |
tazz9924 |
Apr 22 2018, 01:52 AM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
So I broke another bolt off in my rear right trailing arm pick up (the one behind the rocker panel) and i need suggestions for getting it out
914forme |
Apr 22 2018, 07:53 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Tangerine makes a replacement for the threaded insert section if you need it.
Tangerine - Trailing Arm Threaded Mounting Sleeve "The rear outer suspension consoles each have three of these. Our piece is an accurate repro of the factory component. This sleeve makes a quality repair possible if you are unable to repair the threads after breaking a bolt. A 7/8" hole saw will cut through the top weld on the console making it easy to remove the old sleeve." It is a backup to a problem that exists. Also there are plastic plugs at the top of these sleeves. You can add some penetrate. Take a punch and drop it in the top and top the top of the bolt. Rinse and repeat until your ready to give it a try. I have a set of reverse drill bits to give it a fitting chance. Best of luck with this repair. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:09 AM |
