> Making 914-6 GT Style Fuel Gauge Don't Spend Big $$$$, All It Takes Is A 914 Fuel Gauge & Saab 95 96 gauge
914Sixer
post May 2 2018, 05:10 PM
You need the Saab fuel gauge and an early 914 fuel gauge with the round black plugs on it. Take the Saab fuel gauge apart starting with the ring and face. Go around back and remove the 3 screws. Drop gauge out the front. Take a small fork and gently pull up on the needle. Take two screw off dial face. They are VERY SMALL. Turn assembly over and undo the two ground nuts and plug. Be careful pulling apart. There is two small washers on the base. Unit and mounting will come apart. NOTE THE TWO WIRE CONNECTIONS. Unsoder the wires. Now your ready to take the 914 gauge apart the same way you did the back of the Saab gauge. Remove needle and face screws. Go around the back and undo one post nut. Base will separate from the back. CHECK WIRE CONNECTIONS. Unsoder from base. Take the 914 unit over to the Saab base and match up the wire terminal. Soder in the wire and capacitor. Reassemble base with two small washers and 1st nut. Put ground spade and 2nd nut on centering the spade. Your conversion is DONE. Ready to send off for face plate silk screening. If you have some needle paint, go ahead and paint it too. (NHS charges $15 to paint needle).
If you started out with a known good gauge your costs should only be for a new black trim ring and silk screen cost. Trim rings are $45 each.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
914Sixer
post May 3 2018, 02:20 PM
I thought this might be a hot ticket after finding out NHS charges $850 to redo one of these.
914Sixer   Making 914-6 GT Style Fuel Gauge Don't Spend Big $$$$   May 2 2018, 05:10 PM
914Sixer   I thought this might be a hot ticket after finding...   May 3 2018, 02:20 PM
pete000   Who is doing the screen printing?   May 3 2018, 04:48 PM
914Sixer   Thinking NHS. I just wanted to make sure of no ou...   May 3 2018, 05:36 PM
914forme   Working with a company right now, on a different p...   May 3 2018, 07:59 PM
Miguel K R   Working with a company right now, on a different ...   Oct 17 2020, 03:28 AM
rgalla9146   :popcorn: Mmmmm. Need this. Great inf...   Oct 17 2020, 05:59 AM
nditiz1   Mark told me the only piece you actually use from ...   Oct 17 2020, 06:54 AM
Retroracer   Re: fascia (and not spending big $$...   Oct 17 2020, 12:46 PM
FlacaProductions   @Retroracer - looks good - which sticker company ...   Oct 17 2020, 01:06 PM
Retroracer   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Oct 17 2020, 03:47 PM
FlacaProductions   Thanks - was having difficulty finding a place tha...   Oct 17 2020, 04:59 PM
914forme   Thanks - was having difficulty finding a place th...   Oct 17 2020, 06:02 PM
nditiz1   Does anyone know where I can buy/get a longer need...   Oct 17 2020, 07:10 PM
Miguel K R   I cannot imagine anyone selling a needle to suit a...   Dec 10 2020, 04:16 PM
914forme   Any sign shop that does vinyl wraps should be able...   Oct 17 2020, 05:52 PM
Montreal914   ...So how exactly did the movement get reversed co...   Dec 10 2020, 08:53 PM
- Lo-Fi Version Time is now: 22nd August 2026 - 12:03 PM
