| Nacho |
May 7 2018, 09:44 PM
Member ![]() ![]() Group: Members Posts: 222 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None
Hi everyone
I want to get my rear control arms powder coated black soon. What I don't want to do is remove my rear original rubber busings as they are in really good shape! Will the bake dry process damage the bushings? thanks |
| Rob-O |
May 9 2018, 11:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,312 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
If you do powdercoat, I’d mask the area that the bushing sits in. Powder usually has a much higher film build thickness. The cheap paint they put on those parts at the factory was probably less than a mil thick. Powder coating can range to about 4 or 5 miles depending on the application, person applying, product, etc. the added film thickness could make installing the new bushings a PITA.
Nacho Powder Coating with Bushings May 7 2018, 09:44 PM
JamesM
Hi everyone
I want to get my rear control arms ... May 7 2018, 10:35 PM
McMark :agree: You can get original style rubber bushings... May 8 2018, 04:25 AM
mepstein I don't think 400 degrees will be good for the... May 8 2018, 04:37 AM
toolguy Must be removed. . a couple of reasons. . most o... May 8 2018, 07:49 AM
Nacho I read so many post suggesting that if your bushin... May 8 2018, 08:31 AM
Mikey914 As a rubber professional, I highly recommend- pull... May 8 2018, 09:43 AM
bob's project You may also want to consider painting your contro... May 8 2018, 11:45 AM
mepstein When I powdercoat, I preheat large parts like trai... May 8 2018, 11:57 AM
Nacho Awesome advise from everyone and many thanks!
... May 8 2018, 12:04 PM
mepstein If you want -like new, elephant racing. They are p... May 8 2018, 04:57 PM
914forme What is the final application, pure street, auto-x... May 8 2018, 06:58 PM
Nacho
What is the final application, pure street, auto-... May 9 2018, 08:58 AM
Nacho
If you do powdercoat, I’d mask the area that th... May 9 2018, 12:59 PM
mepstein I powdercoates where the bushing goes. Went in fin... May 9 2018, 01:49 PM
McMark The rear wheel bearing is a press fit already, so ... May 9 2018, 04:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:29 AM |
