naro914 |
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States ![]() |
For a long time, steering in Huey has been difficult - VERY hard to turn like something was always fighting you. I knew the boot that covers the shaft under the gas tank was never installed so I thought maybe the problem was that the tank was sitting on the shaft or bushings or something.
So today I took out the gas tank and sat looking at it. First....I have no clue how to put the boot on (do I have to drop the rack for that?) but I think the real problem is different. I undid the two allen bolts that hold the U bracket on and slid the rubber bushings out of the was to asses things. Immediately the shaft moved right up against the sides of the hole where it comes through the firewall and relieved the pressure it was under. (see picture) In other words, the shaft was NOT centered at all in that hole, so with the bushings trying to center the shaft, they were putting an immense amount of pressure on the shaft, thus making it hard to turn. (at least this is my theory). In fact, sometimes you can hear a squeaking/creaking type sound when turning the wheel, like metal moving tightly on rubber... I thought "ok, adjust the U-joints to allow the shaft to be centered". no dice since you can't lengthen/shorten the shaft in the U Joints because of the notch they have where the tightening bolt goes through. So....questions for the 914world brain trust: 1) how can I adjust things to get that shaft centered through the firewall hole? 2) how do I get the boot on? 3) where can I get new versions of all those bushings? there seems to be two (1 & 2 in my picture) and I guess a bearing (3)? thoughts? TIA ![]() ![]() |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
Ran the tracking, they still say today. But I called and sounds like they may deliver Sat. I’ll follow up.
Mark |
naro914 |
Ran the tracking, they still say today. But I called and sounds like they may deliver Sat. I’ll follow up. Mark Saturday? Not good. That’s a business address it’s going to and nobody will be there to receive it. I was hoping to install it tonight (Friday) because that’s the only time I have help available. Car needs to be done and off the lift because I have another one to put up there and work on this weekend.... EDIT: just looked at it this morning. It SAYS its in Charlotte, so maybe deliver today...fingers crossed! |
naro914 |
Ran the tracking, they still say today. But I called and sounds like they may deliver Sat. I’ll follow up. Mark Saturday? Not good. That’s a business address it’s going to and nobody will be there to receive it. I was hoping to install it tonight (Friday) because that’s the only time I have help available. Car needs to be done and off the lift because I have another one to put up there and work on this weekend.... EDIT: just looked at it this morning. It SAYS its in Charlotte, so maybe deliver today...fingers crossed! Just got an update....Saturday delivery. Not good... I won’t see it until next week and now no way to get it all installed before the hilllcimb next weekend. Damn... |
Lo-Fi Version | Time is now: 11th July 2025 - 05:25 AM |
