Testing operation of 70-73 Safety Belt Warning Light |
doug_b_928 |
Mar 2 2018, 08:49 PM
Senior Member Group: Members Posts: 693 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I'm trying to determine if my safety belt warning light is good. It's from a 73. The car is completely disassembled, including the wiring harness. There are 4 wires that go to the light. On the back of the light are 4 contact points, one for each wire. When I put power and ground in various combinations to the 4 points, I can only get the light to illuminate when the ground is on the left-most contact point (where the yellow wire goes) and put power to the second contact point from the right (where the black wire goes). Does this sound like the correct operation for this light, or should other power and ground combinations also cause it to illuminate? If no one knows for sure, if anyone has one they could test I'd appreciate it. Here's a pic of the only combination that will illuminate the light.
doug_b_928 |
May 14 2018, 11:33 AM
Yes, powerbon 15 (light on), then making the bridge turned the light off. Thanks so much!!
Lo-Fi Version | Time is now: 9th June 2024 - 10:49 PM |
