Choosing Injectors, for different engine sizes |
McMark |
May 15 2018, 09:54 AM
A question about which injectors to use on a 1911 engine with stock fuel injection made me dig in deeper. So I collected the following info for stock injectors. The critical piece when comparing injectors is the testing fuel pressure. I was able to look up the flow-report some other members had posted, which show the after-cleaning flow rates. A set of 2.0 injectors flow tested at 42 lb/hr, confirming the 380cc @ 2bar rating that's been passed around. So using that, I built the following table using the typically reported flow rates for the other stock injectors.
(IMG:http://www.914world.com/bbs2/uploads/post-419-1526397753.png) I was looking at these injectors at FiveOMotorsports. The FiveO injectors don't explicitly state their testing pressure, but industry standard is 3-bar. So using the chart above you can find the best fit injectors for stock replacement. BUT YOU MUST CONSIDER WHAT FUEL PRESSURE YOU WANT TO RUN. Considering a stock 2.0, you either need 475cc@3bar injectors at 28psi, OR 380cc@3bar injectors at 43psi. And higher fuel pressure improves atomization, so I'd upgrade to 3bar fuel pressure. and now to get to the actual question, "What injectors to use with a 1911?" you also have to consider the collection of components your using. I'm going to answer this based on the assumption that you're using a complete and correct setup, meaning matching ECU, MPS, etc. (also note: cam choice can make a difference here too because different cams will have different VE results) Okay, so here we go: (IMG:http://www.914world.com/bbs2/uploads/post-419-1526399085.png) So a 1911 is 14% bigger than a stock 1.7. So assuming you had a perfect, complete 1.7 fuel injection system (which implies 'perfect' tuning) that you were installing on a 1911, you would use 380cc@3bar injectors, run at 28psi to compensate for the increase in displacement. The 1.8 injection would work best with 250cc@3bar running at 28psi and 2.0 injection would work bets with 450cc@3bar injectors run at 28psi. My thinking, as I type this, is that the tuning of the stock fuel injection is tied to the ECU, MPS and Injectors (mostly). So which collection of components you're using would change which 'upgraded' injectors you would need for a 1911. Okay, I'm even confusing myself with some of this info. Ask questions... |
Mark Henry |
May 15 2018, 10:30 AM
Stock 1.8 is out, l-jet injectors don't have tolerance for adjustment.
Both stock 1.7 and 2.0 should work, 2.0 are huge, but IIRC both are peak and hold. You likely will have to mess with a rheostat/resistors and fuel pressures. Stock injectors are low impedance, most newer styles are high impedance. You could try cutting the ballast resistors out for high impedance, but you run the risk of frying the board. Never tried it, no clue if it would work, do so at own risk. |
McMark |
May 15 2018, 11:13 AM
Stock 1.8 is out, l-jet injectors don't have tolerance for adjustment. I think your saying 'fuel pressure adjustment'. And from the stock setup perspective, you're absolutely right. This topic gets complicated really quickly, for example there are stock style, adjustable, manifold ported fuel pressure regulators available which would work on a 1.8. But then it's not stock. Like most things fuel injection, there's multiple approaches. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:03 AM |
