Starting issue, Click and no start -intermittent |
North Coast Jim |
May 9 2018, 12:37 PM
Member Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Car has been back together now for 10 months. In heated storage all this past winter. I've put approx. 1K miles on it in that time with zero issues.
Since back on the road this Spring I've put 400 miles on it along with a trip to Mid-Ohio for the IMSA race. In that time I've had 2 instances of a no start. Turning the key produces a click in the area of the starter and the GEN and OIL pressure lights dim dramatically. Waiting and continued trying will produce a normal start. On the second no start I did cycle the headlights. All components are NEW. Ignition switch, Bosch type, Starter, along with the Bowlsly supplied GEN/Start cable. New starter positive cable along with an Optima red top battery. After start the car runs fine and the Gen produces normal voltage output (by gauge not actually measured). As for it being a hot start issue the first instance was after a 35 mile run when I stopped for gas. The second instance was after a 15 mile run but the car sat for over an hour. Outside air temp was 65 degrees. So I think we can rule that out. Fuel pump has been relocated to under the front gravel pan. Car is Weber carb'd now. New rebuilt engine 2. This morning I did climb under the car and all connections are tight. The starter positive cable, the red wire and the yellow wire. No corrosion - there new. Any ideas where to start ?? (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/dry.gif) |
Mblizzard |
May 18 2018, 08:21 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well I to spent much time chasing a start issue. Turned out to be switch on column. simple $15 fix. worked for a few months and then back. Another $15 switch = a few months.
Ordered $50 German switch from dealer no issues. I currently run the hot start set up. I certainly don't think I am smarter than the German engineers that designed the starting system. But they never designed these cars to have a life span of 40+ years. Time takes its toll on high draw electrical systems and the resistance in the system increases making switches have to draw more current. So while it is good advice to fix what is wrong first, it is also important to understand that these cars are well beyond their expected life spans and a bit of modern protection of the electrical systems is a good step to limit future problems. A simple relay system which as Mark said is removable is pretty cheap insurance. While I opted for a modern relay instead of the Ford, I have a Ford solenoid on the shelf just in case. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:13 PM |
