1976 Restoration |
1976 Restoration |
Burk |
May 17 2018, 07:54 PM
Newbie Group: Members Posts: 3 Joined: 12-March 18 From: Magnolia, Tx Member No.: 21,961 Region Association: None |
I picked up a 1976 with a 2l a few months ago and finally started tearing the car down. Fairly clean car that has had paint once in its life. It should have been white but has been painted silver. Ive worked on type 1's quite a bit in the past and have a 65 I am currently working on as well. This is my first 914 so somewhat of a learning curve.
After the EFI quit working the previous owners parked it and left the engine cover open. Over its life quite a bit of water got into the intake and ruined the jugs. I got the engine torn down the case looks immaculate has all std. bearings that all measure out including thrust. Something that stands out to me as weird is the two plugs near where the oil filter mount is bolted are staked in and had some kind of material covering them and the plug to the bell-housing side of the same oil tract has the same. I cannot tell that the case was opened but I really have no idea. The case has silver paint over the aluminum and the paint is over the epoxy material on the staked plugs. BUT there is a faint blue lettering /rubber stamping below the oil fill box. Its definitely a 2l engine but I'm hoping on some insight to the case and why there would be epoxy over those plugs other than a leak. |
Dave_Darling |
May 18 2018, 08:59 AM
AFAIK, the epoxy was never done at the factory.
It used to be conventional wisdom to epoxy over the plugs any time the engine was out, not necessarily just when it was apart. The 93.96 and + are factory markings on the pistons. I'm not sure, but the 1-4 sounds like something that a rebuilder would do, not something done at the factory. The blue ink stamping rings a bell, but I don't remember where from. --DD |
Lo-Fi Version | Time is now: 8th June 2024 - 12:58 AM |
