Fuel pump help, Please |
gster |
May 19 2018, 02:55 PM
Newbie Group: Members Posts: 11 Joined: 15-April 17 From: canada Member No.: 21,021 Region Association: Canada |
I've installed an Airtex pump on the car as recommended by many.
The car does run but terribly.... I hope I've installed correctly and put the "T" adapter in the right place. The fuel line from the tank goes to the filter then to the pump. The pump output line is then T-eed to the other 2 lines.... Have I got this wrong? Is the filter restricting flow? The car has been sitting awhile and I've put fresh gas in. Otherwise nothing has changed. Any help is appreciated. |
Mark Henry |
May 19 2018, 08:00 PM
I can't remember what the 3rd line does, but I think it's an overpressure relief or balance. Not required on a two port pump, remove the plastic y fitting, you don't need a t fitting. Plug or remove the extra hose.
Lo-Fi Version | Time is now: 23rd May 2024 - 10:39 AM |
