Fuel pump help, Please |
gster |
May 19 2018, 02:55 PM
Newbie Group: Members Posts: 11 Joined: 15-April 17 From: canada Member No.: 21,021 Region Association: Canada |
I've installed an Airtex pump on the car as recommended by many.
The car does run but terribly.... I hope I've installed correctly and put the "T" adapter in the right place. The fuel line from the tank goes to the filter then to the pump. The pump output line is then T-eed to the other 2 lines.... Have I got this wrong? Is the filter restricting flow? The car has been sitting awhile and I've put fresh gas in. Otherwise nothing has changed. Any help is appreciated. |
brownaar |
May 20 2018, 11:40 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
I switched to the two-port pump several months ago. Plumbing is easy, a single circuit. Fuel tank➡️filter➡️pump➡️engine(fuel rail farthest from pressure regulator)➡️pressure regulator➡️fuel tank. There should be no tee or y in this setup.
Lo-Fi Version | Time is now: 6th June 2024 - 07:40 AM |
