Slightly tailhappy... |
falcor75 |
May 18 2018, 01:15 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
I need to learn a bit of how to setup my car better.
Its got new Bilstein shocks all around, new bushings everywhere. Front has the stock torsion bars and a Tarret adjustable swaybar. Rear has 140lbs Weltmeister springs. Last year I ran it with no rear swaybar and the front swaybar set at about 25% from the outer most position. This got the car quite tailhappy when doing autocross/slalom events. During the Winter I added the stock rear swaybar just to see what difference it made and it calmed the tailhappyness down a bit but still a bit twitchy. Whats the next step? Decreaseing the front swaybar setting? Last year in the wet.. https://www.youtube.com/watch?v=yrh878om6pI This years first event https://www.youtube.com/watch?v=Eer4JyMl_PI |
gereed75 |
May 20 2018, 12:56 PM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Mat, Car sounds great and looks great too. Looks fairly neutral in second vid. Not stepping out even during trailing throttle turn in.
Yep, bar in back should increase oversteer. what rear tire pressures were you running?? Good pressures are surprisingly low - in the 22-26 psi range. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:21 AM |
