| falcor75 |
May 24 2018, 11:01 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again. Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation? |
| jcd914 |
May 25 2018, 12:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I have never experienced or heard of an issue like this with oil sender mounted remotely.
I have seen a few that came loose or lost their the ground. I would check to make sure the sender is solidly mounted and has a good ground. If there is nothing there to attribute yoyr symptoms to I would look at the tuna can install. Make sure the pick up tube extension fits tight and goes all the way down to the bottom of the tuna can. I always ran mine 1/2 quart over full of oil in addition to running a tuna can. Jim |
falcor75 911 oil temp / pressure gauge May 24 2018, 11:01 PM
SixerJ Matt, 1st off I’m a 6cyl owner so have little de... May 25 2018, 12:48 AM
914Sixer Not going to be sending unit. Sender is just show... May 25 2018, 07:32 AM
bdstone914 Not the sender,
Do you have a windage tray insta... May 25 2018, 08:35 AM
GeorgeRud You will lose oil feed in a long high G turn, and ... May 25 2018, 09:06 AM
falcor75 I've got a tunacan installed, unsure about the... May 27 2018, 07:44 AM
Jetsetsurfshop I dont think its your pressure gauge. Most likely ... May 27 2018, 08:32 AM
falcor75 Yes I've already started investingating an acc... May 27 2018, 09:44 AM
Jetsetsurfshop Found this in my notes. May 27 2018, 11:35 AM
Frank S How are your heads vented? Don't think you hav... May 27 2018, 04:04 PM
falcor75
Here's the sensor mounting.
I took the... May 28 2018, 12:53 PM
Frank S Hi Mats,
looks all good to me.
Check this:
https... May 29 2018, 12:42 AM
falcor75
Hi Mats,
Check this:
http... May 29 2018, 01:00 AM
falcor75 Tuna can remounted, overfilled with about half a q... Jun 8 2018, 02:19 PM
Frank S Great news.
As you have asked how others have mou... Jun 8 2018, 03:45 PM
falcor75 Is it an adapter first that fits into the M10x1 ho... Jun 9 2018, 12:12 PM
Frank S Hi Mats,
I've used following adaptor:
http://w... Jun 12 2018, 10:57 AM
falcor75 Thanks Frank. I'm toying with the idea of havi... Jun 12 2018, 11:57 AM
falcor75
Heres what I'm thinking of having made. :) Jun 12 2018, 10:46 PM
Frank S Hi Mats,
this would not work with the distributor... Jun 13 2018, 10:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 09:36 PM |
