> 911 oil temp / pressure gauge, how did you mount the pressure sensor?
falcor75
post May 24 2018, 11:01 PM
I installed a 911 oil temp and pressure gauge this Winter.
I didnt want to hack up my engine tins to mount the sensor in the stock location so
I made bracket and mounted it on the fan housing where the stock coil sits and connected it to the oil pressure port with a piece of steel braided hose with the correct end fittings. It works well and doesnt leak but I've noticed that in long sweeping left hand turns I loose oil pressure, it never goes to zero but once or twice the light flickered on and then immediatly turned off again.
Do you think this could be a sensor location thing or perhaps an issue with my tuna can installation?
Jetsetsurfshop
post May 27 2018, 08:32 AM
I dont think its your pressure gauge. Most likely its correct.
I guess someone could of installed the tuna can with out the pick up extender??
Oil pressure was a big deal for me since I share the car in endurance racing. Worried that someone not familiar with a 914 wouldn't pick up on the idiot light or gauge info.
I run an accusump. I've never seen the light come on since. Even with slicks at Sebring.
Maybe something to look into.
falcor75   911 oil temp / pressure gauge   May 24 2018, 11:01 PM
SixerJ   Matt, 1st off I’m a 6cyl owner so have little de...   May 25 2018, 12:48 AM
jcd914   I have never experienced or heard of an issue like...   May 25 2018, 12:59 AM
914Sixer   Not going to be sending unit. Sender is just show...   May 25 2018, 07:32 AM
bdstone914   Not the sender, Do you have a windage tray insta...   May 25 2018, 08:35 AM
GeorgeRud   You will lose oil feed in a long high G turn, and ...   May 25 2018, 09:06 AM
falcor75   I've got a tunacan installed, unsure about the...   May 27 2018, 07:44 AM
Jetsetsurfshop   I dont think its your pressure gauge. Most likely ...   May 27 2018, 08:32 AM
falcor75   Yes I've already started investingating an acc...   May 27 2018, 09:44 AM
Jetsetsurfshop   Found this in my notes.   May 27 2018, 11:35 AM
Frank S   How are your heads vented? Don't think you hav...   May 27 2018, 04:04 PM
falcor75   Here's the sensor mounting. I took the...   May 28 2018, 12:53 PM
Frank S   Hi Mats, looks all good to me. Check this: https...   May 29 2018, 12:42 AM
falcor75   Hi Mats, looks all good to me. Check this: http...   May 29 2018, 01:00 AM
falcor75   Tuna can remounted, overfilled with about half a q...   Jun 8 2018, 02:19 PM
Frank S   Great news. As you have asked how others have mou...   Jun 8 2018, 03:45 PM
falcor75   Is it an adapter first that fits into the M10x1 ho...   Jun 9 2018, 12:12 PM
Frank S   Hi Mats, I've used following adaptor: http://w...   Jun 12 2018, 10:57 AM
falcor75   Thanks Frank. I'm toying with the idea of havi...   Jun 12 2018, 11:57 AM
falcor75   Heres what I'm thinking of having made. :)   Jun 12 2018, 10:46 PM
Frank S   Hi Mats, this would not work with the distributor...   Jun 13 2018, 10:09 AM
- Lo-Fi Version Time is now: 17th September 2026 - 09:36 PM
