> Let's play a game called I have a good 1.7 L bottom end
Tdskip
post May 30 2018, 11:33 AM
Keep it clean gentlemen - grin.
So I find myself with a perfectly good 1.7 L bottom end, give me a radio is on what to do with it to get more power out of it as cheaply as possible but ending up with a reliable and street where the motor.
Take me to school here please, thanks!
914work
post May 30 2018, 11:37 AM
marksteinhilber
post May 30 2018, 11:53 AM
QUOTE(914werke @ May 30 2018, 10:37 AM) *
1911
Concur, it uses existing crank and rods. Select 96mm pistons that will work with those rods and cylinders to go with it. You can go with reworked heads, or perhaps new 1.8 heads set up with increased valve sizes optimized for 1911. You can add power if you choose to use carbs because you can then select a more aggressive cam. Find a recipe for a 1911 that meets your budget. Check out EMW for machine shop and parts prices. Parts also available at AA. Mark
Tdskip   Let's play a game called I have a good 1.7 L bottom end   May 30 2018, 11:33 AM
914werke   1911   May 30 2018, 11:37 AM
marksteinhilber   1911 Concur, it uses existing crank and rods. S...   May 30 2018, 11:53 AM
Tdskip   Since that was not a very good year, I'm assum...   May 30 2018, 12:14 PM
Tdskip   Thank you for that referral, pick up the phone an...   May 30 2018, 12:39 PM
r_towle   turbo, ask McMark. rich   May 30 2018, 04:23 PM
JamesM   What is more important here, cheapest price or ove...   May 30 2018, 05:45 PM
Tdskip   What is more important here, cheapest price or ov...   May 30 2018, 05:47 PM
JamesM   If I go this route it's going to be heavily b...   May 31 2018, 01:07 AM
Valy   You want to split the case to replace the cam and ...   May 30 2018, 08:26 PM
Tdskip   You want to split the case to replace the cam and...   May 30 2018, 08:32 PM
marksteinhilber   You want to split the case to replace the cam an...   May 30 2018, 08:59 PM
Tdskip   EMW also sells cranks or get a good 2.0 L crank t...   May 30 2018, 09:16 PM
marksteinhilber   EMW also sells cranks or get a good 2.0 L crank ...   May 30 2018, 11:27 PM
falcor75   No matter which way you go I'd split the case ...   May 31 2018, 01:40 AM
Racer Chris   Ok, I'll play. Assuming you really have a goo...   May 31 2018, 07:27 AM
majkos1   :agree: Better exhaust system. My old 1.7 woke s...   May 31 2018, 07:53 AM
Tdskip   Thanks all, good tip Chris. I'll factor that i...   May 31 2018, 08:04 AM
Vacca Rabite   Is this for the turbo car? If so, keep the displa...   May 31 2018, 09:15 AM
Tdskip   Is this for the turbo car? If so, keep the displ...   May 31 2018, 12:23 PM
Mblizzard   Will certainly have to second what Chris said...   May 31 2018, 09:25 AM
914werke   1st it was asked what your goal criteria is, expen...   May 31 2018, 09:59 AM
mepstein   Use the 1.7 as a coffee table and drop in a 3.2 :...   May 31 2018, 10:07 AM
Tdskip   Use the 1.7 as a coffee table and drop in a 3.2 ...   May 31 2018, 12:29 PM
marksteinhilber   Use the 1.7 as a coffee table and drop in a 3.2 ...   May 31 2018, 12:51 PM
Tdskip   [quote name='Tdskip' post='2614440' date='May 31 ...   May 31 2018, 12:54 PM
old914dog   Tangerine exhaust is $$ and worth every ...   May 31 2018, 11:39 AM
porschetub   Tangerine exhaust is $$ and worth every...   May 31 2018, 11:52 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:26 PM
