| Tdskip |
May 30 2018, 11:33 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Keep it clean gentlemen - grin.
So I find myself with a perfectly good 1.7 L bottom end, give me a radio is on what to do with it to get more power out of it as cheaply as possible but ending up with a reliable and street where the motor. Take me to school here please, thanks! |
| Mblizzard |
May 31 2018, 09:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Will certainly have to second what Chris said!
As you see from all of the responses, the old saying that the only thing that beats cubic inches (displacement) is cubic dollars, is very true. But regardless of your choice of internal engine mods, the stock FI systems rarely have the ability to take full advantage of the modification. If you have dual carbs already then it may not be such an issue. My suggestion is leave the bottom. Add the 96mm P/Cs. Get 1.8 heads if you can. Add an aftermarket FI system of your choice so you can tune it and get the most out of your mods. |
Tdskip Let's play a game called I have a good 1.7 L bottom end May 30 2018, 11:33 AM
914werke 1911 May 30 2018, 11:37 AM
marksteinhilber
1911
Concur, it uses existing crank and rods. S... May 30 2018, 11:53 AM
Tdskip Since that was not a very good year, I'm assum... May 30 2018, 12:14 PM
Tdskip Thank you for that referral, pick up the phone an... May 30 2018, 12:39 PM
r_towle turbo,
ask McMark.
rich May 30 2018, 04:23 PM
JamesM What is more important here, cheapest price or ove... May 30 2018, 05:45 PM
Tdskip
What is more important here, cheapest price or ov... May 30 2018, 05:47 PM
JamesM
If I go this route it's going to be heavily b... May 31 2018, 01:07 AM
Valy You want to split the case to replace the cam and ... May 30 2018, 08:26 PM
Tdskip
You want to split the case to replace the cam and... May 30 2018, 08:32 PM
marksteinhilber
You want to split the case to replace the cam an... May 30 2018, 08:59 PM
Tdskip
EMW also sells cranks or get a good 2.0 L crank t... May 30 2018, 09:16 PM
marksteinhilber
EMW also sells cranks or get a good 2.0 L crank ... May 30 2018, 11:27 PM
falcor75 No matter which way you go I'd split the case ... May 31 2018, 01:40 AM
Racer Chris Ok, I'll play.
Assuming you really have a goo... May 31 2018, 07:27 AM
majkos1 :agree:
Better exhaust system.
My old 1.7 woke s... May 31 2018, 07:53 AM
Tdskip Thanks all, good tip Chris. I'll factor that i... May 31 2018, 08:04 AM
Vacca Rabite Is this for the turbo car? If so, keep the displa... May 31 2018, 09:15 AM
Tdskip
Is this for the turbo car? If so, keep the displ... May 31 2018, 12:23 PM
914werke 1st it was asked what your goal criteria is, expen... May 31 2018, 09:59 AM
mepstein Use the 1.7 as a coffee table and drop in a 3.2 :... May 31 2018, 10:07 AM
Tdskip
Use the 1.7 as a coffee table and drop in a 3.2 ... May 31 2018, 12:29 PM
marksteinhilber
Use the 1.7 as a coffee table and drop in a 3.2 ... May 31 2018, 12:51 PM
Tdskip
[quote name='Tdskip' post='2614440' date='May 31 ... May 31 2018, 12:54 PM
old914dog Tangerine exhaust is $$ and worth every ... May 31 2018, 11:39 AM
porschetub
Tangerine exhaust is $$ and worth every... May 31 2018, 11:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:35 AM |
