| 914 RZ-1 |
Jun 10 2018, 09:56 PM
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 684 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
1. My car has been sitting for awhile, but it has started up when I needed it to.
I recently took out and put back the transmission. I got everything hooked up and the car would not start. I took a reading across the battery terminals and got 11.87 volts. Is this an indication of a dead battery? 2. I should mention that I unhooked the positive and negative terminals while the trans was out. I also have a battery disconnect on the negative terminal (turn a screw to connect/disconnect). I got sparks when I hooked up the positive and touched the wrench to the car accidentally. 3. I have an Optima Red Top battery that is only about 1-2 years old. 4. I checked all the wire connections related to the trans and didn't see anything. That shouldn't matter anyway, I think. 5. I'm thinking of jump-starting the car and seeing if that works. 6. I'm also thinking of getting a battery charger and hooking that up. Thoughts? |
The Cabinetmaker Did you reconnect the ground strap on top of the t... Jun 11 2018, 05:28 AM
914 RZ-1 I reconnected everything, including the ground str... Jun 11 2018, 11:36 AM
SirAndy I'm wondering what the correct reading for a g... Jun 11 2018, 11:53 AM
porschetub
I'm wondering what the correct reading for a ... Jun 12 2018, 12:17 AM
Chris914n6 A dead cell would make it 10.5v. That just sounds ... Jun 11 2018, 12:04 PM
Bartlett 914
A dead cell would make it 10.5v. That just sounds... Jun 11 2018, 12:48 PM
Mark Henry
A dead cell would make it 10.5v. That just sounds... Jun 11 2018, 12:49 PM
914 RZ-1 Can anyone recommend a charger?
A dead cell wou... Jun 11 2018, 05:33 PM
Philip W. the last battery that I had that died read right a... Jun 11 2018, 12:04 PM
Triaddave Just did all the above. Ended up buying a new red ... Jun 11 2018, 12:49 PM
rhodyguy Plenty of info out there about charging gel batter... Jun 11 2018, 01:24 PM
914 RZ-1 I'm also going to try jump-starting the car wi... Jun 11 2018, 05:35 PM
burton73 The battery man told me that Optima had a problem ... Jun 11 2018, 05:49 PM
plays with cars I'm a fan of the BatteryMINDER brand chargers.... Jun 11 2018, 11:52 PM
Triaddave The reason for me to use the OPTIMA was the fact t... Jun 12 2018, 11:42 AM
914 RZ-1 I solved the problem!
I tried using a jump bo... Jun 13 2018, 10:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd November 2026 - 12:07 AM |
