> Could this work?, 2056 engine combo ?'s
ottox914
post Nov 23 2016, 02:07 PM
The glory that once was.
So here's my long sad story. The turbo motor dies several yrs ago, due to a missed shift at lots of boost and rpm's. I bought a recently re-built motor from a forum member to replace it, thinking this was faster and easier than re-building the turbo motor. Lost a year to a new job, selling an house, buying a house, moving to a new state, bring my retired dad along and getting him re-set in a new environment. Put the re-built motor in this past summer. It kept blowing up. Pulled it and fixed it all summer. Kept the seller updated as to my problems with the "good" motor. Called the seller this fall, who graciously agreed to refund full purchase price.
So now I again have a motorless 914. Trying to figure out an N/A build that uses most of the parts in my shed to keep $$$ down.
I have the pieces in my stash to build the following: 2 good cases to choose from, 2.0 crank and rods, some good iron cylinders to overbore to 96, (would need to buy some KB's to fill them) some heads that Len did that are 40 x 36, (about 75% I/E ratio) that he says will flow about 175 cfm at 50% lift. They have a 50.4cc chamber. So these, with some flat top KB's would yield about 10.5:1 with .040 deck. 2x valve springs, Len is comfortable with this head to 7k rpm if I would need to go there. I have the ITB's and SDS efi to run it all, and as the injectors were sized to support the turbo motor, I expect I have enough headroom to run some E85 "corn" fuel to handle the CR. Should also hold detonation at bay, and engine should run cooler on corn. Not a bad thing for aircooled motors. Kerry hunter exhaust to finish things off.
The wild card is the cam. The cam I had in the turbo motor is still good, not damaged by the over rev. Its ground on a 110 center, has a lift of .500, and is a split duration of 276I/284E, with duration at .050 of 240/249.
When researching cams for the turbo motor, seems lots of folks say a factory cam N/A is a pretty good starting point for a turbo cam. When I go to the Web Cam page for the 914, what I got is bigger than an 86, the "street" cam, but not as wild as 86a or 494.
What think the collective? Will the flow of the head, small-ish intake valve, and big lift of the cam play well as a team? I expect to get alot of "its all in the combo" remarks, but with as much as is known about what I have to build with, and the cam being the big ?, looking for opinions from those more cam-educated than myself on options to use what I got or not.
ottox914
post Jun 18 2018, 01:26 PM
For now. Never say never. While I miss the turbo infused rush of power in the 914, and the problem solving that goes along with boldly going where few have gone before, there are a pair of tuned Audi’s in the garage should I need a boost fix.
Seriously, I probably lost 5 yrs of autocross goofing with the turbo motor, then with the rebuilt (not by me) 2.0 that kept ingesting #3 intake valve, then building this 2056. I need to drive it and enjoy it again.
Building it is fun, but the air cooled orchestra as you thunder thru the gears has its own appeal.
ottox914   Could this work?   Nov 23 2016, 02:07 PM
ottox914   Nothing? Really? Crickets? So here is my reaso...   Nov 25 2016, 06:50 PM
jmill   Your cam has 60 degrees of overlap. The 86a has 70...   Nov 25 2016, 07:11 PM
Mike Bellis   Since you can't turbo a 914, nobody knows what...   Nov 25 2016, 07:17 PM
rick 918-S   I seem to remember reading that stock Injected eng...   Nov 25 2016, 07:35 PM
ottox914   Thank you for the replies. I don't know all th...   Nov 25 2016, 11:34 PM
Mark Henry   It's a 2mm smaller intake valve, I wouldn...   Nov 26 2016, 12:58 AM
ottox914   It's a 2mm smaller intake valve, I wouldn...   Nov 26 2016, 07:41 AM
jmill   What does this all mean? Seems like the lower ov...   Nov 26 2016, 07:48 AM
saigon71   I went with a FAT 440 MP camshaft for my 2056 FI b...   Nov 26 2016, 08:10 AM
ottox914   In searching around, seems lots of folks have done...   Nov 26 2016, 04:48 PM
Steve   I converted to a six 30 years ago, so I have limit...   Nov 27 2016, 11:05 AM
The Cabinetmaker   Your wrong Steve. There are still plenty of 4 cyl...   Nov 28 2016, 07:44 AM
Steve   Your wrong Steve. There are still plenty of 4 cy...   Nov 28 2016, 01:20 PM
The Cabinetmaker   I have noticed the increase of conversions as of l...   Nov 28 2016, 05:27 PM
ottox914   Well, now we got to see how this works out. Motor ...   Jun 15 2018, 11:12 AM
ottox914   Still trying to get video of final run on to you t...   Jun 16 2018, 12:40 PM
McMark   Good numbers. So you're sticking with N/A?   Jun 17 2018, 07:02 AM
ottox914   For now. Never say never. While I miss the turbo i...   Jun 18 2018, 01:26 PM
ConeDodger   For now. Never say never. While I miss the turbo ...   Jun 18 2018, 02:41 PM
ottox914   [quote name='ottox914' post='2620792' date='Jun 1...   Jun 19 2018, 01:42 PM
ConeDodger   [quote name='ottox914' post='2620792' date='Jun ...   Jun 19 2018, 01:53 PM
McMark   Yeah, I’m not trying to encourage you to go afte...   Jun 18 2018, 04:43 PM
ottox914   Finally got that youtube thing going on. Try this...   Jun 18 2018, 09:40 PM
ottox914   Agreed. I have always wanted a 914 that went pppss...   Jun 19 2018, 08:08 PM
- Lo-Fi Version Time is now: 1st August 2025 - 06:45 PM
