> Travis' 72 914-6 Conversion
TravisNeff
post Jun 4 2018, 11:32 PM
I post every so often in the what did you do to your 914 today thread. Figured I would start a separate thread and have some accountability to get this done.
My car is a 72 which along the way I have swapped the original 1.7 engine out for a 2.0 with DJET & a side shift gearbox.
The plan is to convert to a 1974 2.7 liter six with webers. Along the way I need to do some rust repair - which will be a helluva lot more challenging than the engine swap.
Here's what I am starting with.
TravisNeff
post Jun 18 2018, 07:51 PM
Alright, I will get both sizes and some flat bar stock to create the recesses. (IMG:style_emoticons/default/smash.gif)
Scrubbed things down a bit more with a smaller sized wire brush I found, then hosed it down with Metal Prep. That stuff has some STANK.
bbrock
post Jun 18 2018, 08:16 PM
QUOTE(Travis Neff @ Jun 18 2018, 07:51 PM) *
Oh yeah, on the recesses, I made my forms as positives that I hammered what would be recesses on the panel over the bar stock which worked, but is the stupid way unless you really want to work on your upper arm strength. Check out Ben's (mb911) thread for a better way to do it which is to hammer the recesses DOWN into recesses in your forms. (IMG:style_emoticons/default/smash.gif)
Travis Neff   Travis' 72 914-6 Conversion   Jun 4 2018, 11:32 PM
Travis Neff   Out comes the 2.0   Jun 4 2018, 11:33 PM
Travis Neff   The gearbox was leaking pretty bad, I had messed u...   Jun 4 2018, 11:37 PM
Travis Neff   Here's the engine. It is a 1974 2.7 engine (n...   Jun 4 2018, 11:51 PM
Travis Neff   Well onto the not so fun stuff. Rust Repair. Seve...   Jun 5 2018, 12:01 AM
horizontally-opposed   Nice ride. There is just something VERY cool abo...   Jun 5 2018, 12:03 AM
Travis Neff   Nice ride. There is just something VERY cool ab...   Jun 5 2018, 12:22 AM
Travis Neff   Moving onto the engine compartment. The top of my...   Jun 5 2018, 12:18 AM
Travis Neff   With all this welding that I have to do, it is tim...   Jun 5 2018, 12:28 AM
Travis Neff   Oh, along the way I cleaned up the engine compartm...   Jun 5 2018, 12:30 AM
Travis Neff   I have the transmission all bolted up to the engin...   Jun 5 2018, 12:42 AM
Travis Neff   Sometime in the past both jack points were replace...   Jun 5 2018, 12:55 AM
rick 918-S   Very memorable day! Remember that Prius... Car...   Jun 5 2018, 04:01 AM
Travis Neff   Very memorable day! Remember that Prius... Ca...   Jun 5 2018, 04:16 PM
Dion   Nice work Travis. I do like the green with the gra...   Jun 5 2018, 05:51 AM
mb911   Looks great.. Fun projects.. Ping me if you need a...   Jun 5 2018, 06:31 AM
JOEPROPER   I like the green wheels! This looks like the ...   Jun 5 2018, 07:08 AM
914dave   Nice work! Should be a nice combo. Well worth...   Jun 5 2018, 07:22 AM
Travis Neff   With that last photo of the replaced jack point an...   Jun 5 2018, 04:18 PM
Travis Neff   The long was stuffed with what looks to be Cotton....   Jun 5 2018, 04:26 PM
Travis Neff   And a little view of the jack point repair. They ...   Jun 5 2018, 04:29 PM
JRust   Wow travis you are flying man. I've still got ...   Jun 5 2018, 05:44 PM
Coondog   Wow amazing job !!!   Jun 5 2018, 06:04 PM
Travis Neff   Been sidetracked for a few days. Battery tray pat...   Jun 12 2018, 06:08 PM
914forme   Long steal tubes welded a front crossmember and ti...   Jun 12 2018, 06:19 PM
Travis Neff   I am hoping that I do not need to build a frame. ...   Jun 12 2018, 07:16 PM
bryanc   Nice work Travis!   Jun 12 2018, 08:57 PM
Travis Neff   Thanks Bryan! Good to see you :beer2: I fo...   Jun 12 2018, 11:45 PM
rick 918-S   Thanks Bryan! Good to see you :beer2: I f...   Jun 13 2018, 05:22 AM
porschetub   I post every so often in the what did you do to y...   Jun 12 2018, 11:54 PM
Travis Neff   I will change out the mechanical tensioners, but I...   Jun 13 2018, 12:02 AM
daytona   Nice looking car and all the work looks good. But ...   Jun 13 2018, 06:02 AM
mb911   What are you using for exhaust?   Jun 13 2018, 06:19 AM
mepstein   I’m a chicken shit. I would never work under a c...   Jun 13 2018, 06:28 AM
914forme   Travis I would screw a bunch of 2z4s in a stack to...   Jun 13 2018, 10:08 AM
Travis Neff   I'll take a look at adding a 4x4 as a 2nd i-be...   Jun 13 2018, 10:50 AM
mepstein   Bob Saville , naro Motorsports for the engine moun...   Jun 13 2018, 11:19 AM
Travis Neff   I was going to buy from Bob as his looks like they...   Jun 13 2018, 11:27 AM
Travis Neff   Thanks for all the input so far, I appreciate the ...   Jun 13 2018, 01:31 PM
Mueller   Thanks for all the input so far, I appreciate the...   Jun 13 2018, 04:10 PM
sixnotfour   good work :welder:   Jun 13 2018, 03:04 PM
mepstein   I throw extra wheels with tires under the car. I a...   Jun 13 2018, 03:35 PM
Travis Neff   I added a 4th jack stand underneath the tunnel abo...   Jun 13 2018, 03:48 PM
mb911   I need to post the picture of my no fail jack stan...   Jun 13 2018, 03:55 PM
Travis Neff   I need to post the picture of my no fail jack sta...   Jun 13 2018, 05:29 PM
mepstein   I need to post the picture of my no fail jack sta...   Jun 13 2018, 06:24 PM
Travis Neff   The ramp stand is already screwed down to the wood...   Jun 13 2018, 05:28 PM
djb   Really great thread! Consider using a water l...   Jun 13 2018, 10:10 PM
Travis Neff   Really great thread! Consider using a water ...   Jun 13 2018, 10:40 PM
Larmo63   Your project looks well on it's way to success...   Jun 14 2018, 07:48 AM
mb911   Here is the jack stand that is none fail..   Jun 14 2018, 09:42 AM
Travis Neff   Thanks for the vote of confidence Larmo! OK, ...   Jun 14 2018, 03:06 PM
mb911   Thanks for the vote of confidence Larmo! OK,...   Jun 14 2018, 04:03 PM
mepstein   Thanks for the vote of confidence Larmo! OK...   Jun 14 2018, 04:27 PM
Travis Neff   It was a Montana car that I got from Craig at camp...   Jun 14 2018, 04:31 PM
Travis Neff   I started grinding the paint away where I needed t...   Jun 14 2018, 10:50 PM
Travis Neff   All burned in. Not the prettiest, but it will work...   Jun 14 2018, 10:52 PM
mb911   Speaking from a welding instructor stand point you...   Jun 15 2018, 02:36 PM
Travis Neff   Understood. I am in the middle and just cropped of...   Jun 15 2018, 03:03 PM
mb911   Understood. I am in the middle and just cropped o...   Jun 15 2018, 03:37 PM
Travis Neff   Got it, thank you :)   Jun 15 2018, 04:57 PM
mb911   Btw I like the project. Looks like a great start.   Jun 15 2018, 05:34 PM
Larmo63   I see you took the /4 mounts out, I left mine in. ...   Jun 15 2018, 05:43 PM
Ferg   Looking Good!   Jun 15 2018, 09:17 PM
Justinp71   Cool! You're going to love that motor when...   Jun 15 2018, 10:20 PM
mb911   When removing my 4 mounts I made 14 gauge over lay...   Jun 16 2018, 06:22 AM
Travis Neff   I thought about leaving the mounts in when I had t...   Jun 16 2018, 11:11 AM
mb911   I thought about leaving the mounts in when I had ...   Jun 16 2018, 11:20 AM
Travis Neff   Beautiful! Obviously not done with a metal glu...   Jun 16 2018, 11:23 AM
mb911   Beautiful! Obviously not done with a metal gl...   Jun 16 2018, 12:47 PM
Travis Neff   More practice today. I won't keep boring you ...   Jun 16 2018, 03:26 PM
mb911   Keep it up.. Now your up to the job. Carry on..   Jun 18 2018, 06:57 AM
Travis Neff   Let's pucker up and start to cut..   Jun 18 2018, 03:59 PM
bbrock   Let's pucker up and start to cut.. I know t...   Jun 18 2018, 04:19 PM
mb911   Btdt.. Oh what fun.   Jun 18 2018, 04:13 PM
Travis Neff   A bunch more cotton and mouse trash fell out of th...   Jun 18 2018, 04:26 PM
Travis Neff   I think I will cut these 2 parts next. I will nee...   Jun 18 2018, 04:51 PM
bbrock   I have the same cheapo HF bending brake and bendin...   Jun 18 2018, 05:00 PM
Travis Neff   I have the same cheapo HF bending brake and bendi...   Jun 18 2018, 06:27 PM
bbrock   [quote name='bbrock' post='2620898' date='Jun 18 ...   Jun 18 2018, 07:31 PM
Travis Neff   A little more cancer cuts   Jun 18 2018, 06:38 PM
Travis Neff   Alright, I will get both sizes and some flat bar s...   Jun 18 2018, 07:51 PM
bbrock   Alright, I will get both sizes and some flat bar ...   Jun 18 2018, 08:16 PM
Travis Neff   Found it! Thanks for the tip and thanks to Be...   Jun 18 2018, 08:43 PM
mb911   Found it! Thanks for the tip and thanks to B...   Jun 19 2018, 05:06 AM
Travis Neff   That would save me some serious time! I would...   Jun 19 2018, 10:08 AM
mb911   That would save me some serious time! I woul...   Jun 20 2018, 05:11 AM
Travis Neff   Brent, thanks for the tip on the round bar. 1/2 an...   Jun 19 2018, 09:47 PM
bbrock   Brent, thanks for the tip on the round bar. 1/2 a...   Jun 19 2018, 11:13 PM
Travis Neff   Either way would be fantastic!   Jun 20 2018, 08:50 AM
Travis Neff   Patched a small part of long and put a backer in p...   Jun 21 2018, 11:18 PM
Travis Neff   Forgot a pic of the good looking side   Jun 21 2018, 11:27 PM
Travis Neff   I put in the backing panel against the inside long...   Jun 23 2018, 09:57 PM
mb911   I put in the backing panel against the inside lon...   Jun 24 2018, 05:00 AM
Travis Neff   I put in the backing panel against the inside lo...   Jun 24 2018, 10:08 AM
Travis Neff   Patch is in. Had to grind down some the welds to ...   Jun 24 2018, 02:31 PM
Travis Neff   Moving on.. This cut exercised my pelvic floor pr...   Jun 24 2018, 04:15 PM
Travis Neff   Looked a little further and the bump for the -4 mo...   Jun 24 2018, 07:34 PM
bbrock   Looked a little further and the bump for the -4 m...   Jun 24 2018, 08:40 PM
Travis Neff   I am officially sick of rust repair, LOL. I mad...   Jul 3 2018, 05:33 PM
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 6th November 2026 - 05:51 PM
