Resto-Mod AC system, Miata AC? |
BPic |
Jun 24 2018, 08:11 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I need to add AC to my 72 914 to get my wife in it for anything longer than a trip to the grocery store. I'm currently down to the tub and doing rust repairs now, but think I should plan this out for wiring, AC lines, etc. at this point.
I used to have a Miata and the AC was great so I thought it would be a good system to 'Mod" in. This is a 3 part system and I would eliminate the heater section and run just the blower and Evaporator sections. Original plan: I can get the compete Miata AC system, evap, blower, condenser, controls, relays, everything for about $250. (it appears that the Miata units will fit) Have custom lines made and install the condenser in the frunk in the renegade radiator spot. I would then customize an air dam to pull air in. So I would not position the condenser in the normal aftermarket hole in floor. I would also add a custom gauge console and hide the controls in it and add 2 - 914 vents into it as well and have the air vent through the original dash vents and the 2 new ones. Being in Miami I don't need or want the heater so that would all be eliminated. Has anyone done this and if so what manufacture AC did you use? Or am I totally nuts to think this is possible? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/screwy.gif) Thanks in advance for any thoughts, crticism, assistance, or opinions. |
914forme |
Jun 24 2018, 10:38 AM
If your running. center console and don't mind doing a bit of fabrication than I would think One of these might do the trick.
Mini Cooler Or wait for McMark to get his done, I think it was Mark (IMG:style_emoticons/default/confused24.gif) Also a great write up on here for another version by Larry Hubby, he did a series of 4 posts on what he did. This will give you an idea of his setup and make you dig a bit deeper. |
Steve |
Jun 24 2018, 01:49 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
If your running. center console and don't mind doing a bit of fabrication than I would think One of these might do the trick. Mini Cooler Or wait for McMark to get his done, I think it was Mark (IMG:style_emoticons/default/confused24.gif) Also a great write up on here for another version by Larry Hubby, he did a series of 4 posts on what he did. This will give you an idea of his setup and make you dig a bit deeper. That’s what I plan on doing as well as an electric compressor. Just no time to put it together. I have the condenser already installed. |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:52 PM |
