Idle temperature, CHT under #3 |
nditiz1 |
Jun 24 2018, 05:45 PM
Senior Member Group: Members Posts: 1,190 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I just finished rebuilding my 2056 and while I'm not done setting everything (carbs), it was idling pretty smooth around 1100 RPM. The temp on the CHT gauge raised to 300 after about 20 mins. Just checking if this is normal idle behavior. The stock temp gauge didn't go up much. Running 10/40 Brad Penn. 84 degrees and humid outside (car was in the garage)
VaccaRabite |
Jun 25 2018, 06:58 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
When you sync your carbs and set idle, REMEMBER that you idle will change when the engine is hot. If you set idle while the engine is still warming up, your nice 1100 rpm idle will be an 1500rpm idle when warm.
Waiting for the engine to be warm will ensure a good driving idle, but may make starting the car a bit more tricky, since there is no choke. Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:51 AM |
