Fuel Sender, Removed |
stevend914 |
Jun 28 2018, 12:06 PM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
...and taken apart. Float seemed to run up and down ok but cleaned everything anyway. Two silver wires and one copper wire all look ok. Is there anything else I should look at before putting it back together? (IMG:style_emoticons/default/smash.gif)
914Sixer |
Jun 28 2018, 12:22 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
No, that should be it. You could have simply taken a tall glass and filled it with lacquer thinner and set the assembly in it. Pin hole would fill up the fuel cylinder. Slosh it around after setting for awhile with your finger over the hole.. Repeat several times. Drain out thinner. Tilt cylinder back and forth and listen for float moving. Works 99% of the time.
Lo-Fi Version | Time is now: 2nd June 2024 - 09:11 AM |
