> VPC York compressor Dealer AC, R134A Fill
jdamiano
post Jun 28 2018, 06:55 PM
My car has the dealership installed VPC AC. I purchased the car 5 months ago and the AC doesn’t blow cold. I have no history on it. Still had a little pressure in the system. I’m thinking of charging it with R134. Has anyone done this and know how if it will work and how much I should try to put in the system?
ClayPerrine
post Jun 28 2018, 07:09 PM
QUOTE(jdamiano @ Jun 28 2018, 07:55 PM) *
The VPC ac system used R-12. Charging it with R-134a will ruin the system. They are NOT compatible.
The York compressor won't work with R-134a. You will have to use a rotary compressor to use R-134a.
You also need to change out all the hoses for barrier hose, and replace the expansion valve. You will get AC that works, but is not ice cold. To get ice cold, you have to add an additional condenser. I used a 911SC condenser mounted under the engine lid in place of the rain tray. Put two 12" fans on it, and you are good to go.
The AC in Betty's 914 blows ice cold on a 100 degree Texas summer day... like today.
jdamiano   VPC York compressor Dealer AC   Jun 28 2018, 06:55 PM
ClayPerrine   My car has the dealership installed VPC AC. I pur...   Jun 28 2018, 07:09 PM
914forme   Good list Clay as usual, you will also need to rep...   Jun 28 2018, 07:27 PM
MarkV   If you are just trying to get the system working a...   Jun 28 2018, 11:53 PM
Mblizzard   If you are just trying to get the system working ...   Jun 29 2018, 11:32 AM
JamesM   http://redtek.com/English/product.asp?ID=18 I wou...   Jun 29 2018, 03:30 PM
Chris914n6   It's more work but replacing the compressor wi...   Jun 29 2018, 01:53 AM
jcd914   R134 molecules are smaller than R12 molecules and ...   Jun 29 2018, 10:44 AM
Chris914n6   R134 is also not as thermally efficient as R12, s...   Jun 29 2018, 02:15 PM
76-914   They can be too large. also. My power plant is out...   Jun 29 2018, 11:07 AM
Chris914n6   They can be too large. also. My power plant is ou...   Jun 29 2018, 02:24 PM
Amphicar770   I redid my AC system back in 2013. Still blowing ...   Jun 29 2018, 01:43 PM
dr914@autoatlanta.com   We only put r12 in the original 914 ac systems, DP...   Jun 29 2018, 02:00 PM
914forme   Well in reality it does not matter what your using...   Jun 29 2018, 04:16 PM
ClayPerrine   Or switch over to an electric compressor system...   Jun 30 2018, 07:47 AM
Dave_Darling   Another good part about the electric compressor is...   Jun 30 2018, 09:18 AM
914forme   Thanks Clay, just solved two of my problems, now I...   Jun 30 2018, 03:50 PM
ClayPerrine   Thanks Clay, just solved two of my problems, now ...   Jun 30 2018, 04:53 PM
914forme   Thanks Clay, just solved two of my problems, now...   Jun 30 2018, 07:04 PM
ClayPerrine   [quote name='ClayPerrine' post='2624968' date='Ju...   Jul 1 2018, 06:07 AM
914forme   This seems like a good solution for a high amp alt...   Jul 1 2018, 09:05 AM
ClayPerrine   Just for education purposes... Here are some pict...   Jul 1 2018, 09:48 AM
914forme   Just for education purposes... I actually tried...   Jul 1 2018, 11:49 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:12 PM
