| jdamiano |
Jun 28 2018, 06:55 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car has the dealership installed VPC AC. I purchased the car 5 months ago and the AC doesn’t blow cold. I have no history on it. Still had a little pressure in the system. I’m thinking of charging it with R134. Has anyone done this and know how if it will work and how much I should try to put in the system?
| Chris914n6 |
Jun 29 2018, 01:53 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,528 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
It's more work but replacing the compressor with a modern Sanden is worth it.
The r12 oil + r134 = gel... so no good. You will need to flush out all the old oil from the whole system then use the hybrid swap over oil. New dryer but it's a generic size so that's easy. The rest of the hard parts will work fine. The fittings will be r12 so you will have to buy a set of ac gauges and do it yourself or buy the adapter fittings to get a shop to do it. Refill is done best by pressures. You will also need to apply vacuum to the system before fill to remove the air and moisture to get the best result. Having a local hose place make new hoses will be a couple bills, but they'll last decades. I don't know if old hose will play nicely with r134 and the oil. |
jdamiano VPC York compressor Dealer AC Jun 28 2018, 06:55 PM
ClayPerrine
My car has the dealership installed VPC AC. I pur... Jun 28 2018, 07:09 PM
914forme Good list Clay as usual, you will also need to rep... Jun 28 2018, 07:27 PM
MarkV If you are just trying to get the system working a... Jun 28 2018, 11:53 PM
Mblizzard
If you are just trying to get the system working ... Jun 29 2018, 11:32 AM
JamesM http://redtek.com/English/product.asp?ID=18
I wou... Jun 29 2018, 03:30 PM
jcd914 R134 molecules are smaller than R12 molecules and ... Jun 29 2018, 10:44 AM
Chris914n6
R134 is also not as thermally efficient as R12, s... Jun 29 2018, 02:15 PM
76-914 They can be too large. also. My power plant is out... Jun 29 2018, 11:07 AM
Chris914n6
They can be too large. also. My power plant is ou... Jun 29 2018, 02:24 PM
Amphicar770 I redid my AC system back in 2013. Still blowing ... Jun 29 2018, 01:43 PM
dr914@autoatlanta.com We only put r12 in the original 914 ac systems, DP... Jun 29 2018, 02:00 PM
914forme Well in reality it does not matter what your using... Jun 29 2018, 04:16 PM
ClayPerrine
Or switch over to an electric compressor system... Jun 30 2018, 07:47 AM
Dave_Darling Another good part about the electric compressor is... Jun 30 2018, 09:18 AM
914forme Thanks Clay, just solved two of my problems, now I... Jun 30 2018, 03:50 PM
ClayPerrine
Thanks Clay, just solved two of my problems, now ... Jun 30 2018, 04:53 PM
914forme
Thanks Clay, just solved two of my problems, now... Jun 30 2018, 07:04 PM
ClayPerrine
[quote name='ClayPerrine' post='2624968' date='Ju... Jul 1 2018, 06:07 AM
914forme This seems like a good solution for a high amp alt... Jul 1 2018, 09:05 AM
ClayPerrine Just for education purposes...
Here are some pict... Jul 1 2018, 09:48 AM
914forme
I actually tried... Jul 1 2018, 11:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
