> VPC York compressor Dealer AC, R134A Fill
jdamiano
post Jun 28 2018, 06:55 PM
My car has the dealership installed VPC AC. I purchased the car 5 months ago and the AC doesn’t blow cold. I have no history on it. Still had a little pressure in the system. I’m thinking of charging it with R134. Has anyone done this and know how if it will work and how much I should try to put in the system?
jcd914
post Jun 29 2018, 10:44 AM
R134 molecules are smaller than R12 molecules and they leak out through the old hoses, even if the old hoses were new the R134 would leak out through them. This is why you need new barrier hoses.
R134 is also not as thermally efficient as R12, so a R134 system has to be bigger to provide the same cooling capacity as a R12 system. This is why an additional condensor or a larger condensor is needed. The rotary compressor also moves more freon with less load on the engine than the York piston compressor.
R12 systems are expensive to upgrade but they are also expensive to maintain. R12 is probably $50 a pound and the system has to be serviced by a licensed tech (at least in CA).
Jim
jdamiano   VPC York compressor Dealer AC   Jun 28 2018, 06:55 PM
ClayPerrine   My car has the dealership installed VPC AC. I pur...   Jun 28 2018, 07:09 PM
914forme   Good list Clay as usual, you will also need to rep...   Jun 28 2018, 07:27 PM
MarkV   If you are just trying to get the system working a...   Jun 28 2018, 11:53 PM
Mblizzard   If you are just trying to get the system working ...   Jun 29 2018, 11:32 AM
JamesM   http://redtek.com/English/product.asp?ID=18 I wou...   Jun 29 2018, 03:30 PM
Chris914n6   It's more work but replacing the compressor wi...   Jun 29 2018, 01:53 AM
jcd914   R134 molecules are smaller than R12 molecules and ...   Jun 29 2018, 10:44 AM
Chris914n6   R134 is also not as thermally efficient as R12, s...   Jun 29 2018, 02:15 PM
76-914   They can be too large. also. My power plant is out...   Jun 29 2018, 11:07 AM
Chris914n6   They can be too large. also. My power plant is ou...   Jun 29 2018, 02:24 PM
Amphicar770   I redid my AC system back in 2013. Still blowing ...   Jun 29 2018, 01:43 PM
dr914@autoatlanta.com   We only put r12 in the original 914 ac systems, DP...   Jun 29 2018, 02:00 PM
914forme   Well in reality it does not matter what your using...   Jun 29 2018, 04:16 PM
ClayPerrine   Or switch over to an electric compressor system...   Jun 30 2018, 07:47 AM
Dave_Darling   Another good part about the electric compressor is...   Jun 30 2018, 09:18 AM
914forme   Thanks Clay, just solved two of my problems, now I...   Jun 30 2018, 03:50 PM
ClayPerrine   Thanks Clay, just solved two of my problems, now ...   Jun 30 2018, 04:53 PM
914forme   Thanks Clay, just solved two of my problems, now...   Jun 30 2018, 07:04 PM
ClayPerrine   [quote name='ClayPerrine' post='2624968' date='Ju...   Jul 1 2018, 06:07 AM
914forme   This seems like a good solution for a high amp alt...   Jul 1 2018, 09:05 AM
ClayPerrine   Just for education purposes... Here are some pict...   Jul 1 2018, 09:48 AM
914forme   Just for education purposes... I actually tried...   Jul 1 2018, 11:49 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:03 PM
