| jdamiano |
Jun 28 2018, 06:55 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car has the dealership installed VPC AC. I purchased the car 5 months ago and the AC doesn’t blow cold. I have no history on it. Still had a little pressure in the system. I’m thinking of charging it with R134. Has anyone done this and know how if it will work and how much I should try to put in the system?
| Amphicar770 |
Jun 29 2018, 01:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,229 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region
I redid my AC system back in 2013. Still blowing ice cold.
As others have noted, simply pumping in refrigerant will likely be a fail. Even if it works briefly, the old hoses, seals, connectors, etc. will likely leak. Additionally, You can not put R134 into and R12 system without flushing out all the old oil from every part of the system (which you should probably do anyway). You will definitely need a new receiver-drier at the VERY minimum. The first step in testing for leaks should not be to put freon in but rather to take air out. Vacuum down the system via manifold gauges. Let it sit overnight. If you lose vacuum then the system has a leak. I went with a Sanden style compressor but kept everything R12 (I stocked up years ago and yes, I am licenced). Original condensor, evaporator, fan and it blows ice cold. The Sanden style compressors rob a LOT fewer horsepower that the heavy York boat anchors (approx 2HP vs approx 12HP) 1. The Seltec compressor is model 103-55021. It fits but snugly. Might have been easier with next size down. 2. For me, the proper belt turned out to be a Dayco 15460 from Advance Auto Parts. As noted, you do not get a lot of room to adjust belt tension. Make sure you have the pulley behind the fan lined up right or you will need to do it over again (as I learned). 3. This job would be a pain without a lift. If the engine were out it should also be easier. Would not want to tackle this job on my back. 4. I replaced hose and fittings with Aeroquip EZ-Clip components. The hose is more flexible than barrier hose and the clip system is easier than crimping. Size 8 hose on the high pressure side, size 10 for low side, a small piece of #6 from condensor to receiver drier. Finding R12 Aeroquip fittings was a challenge. 5. I stuck with R12. You need to drain approx 4 oz of oil from compressor and replace with mineral oil (available at Napa). If you flush out the evaporator and condenser, add an ounce per component. (You need to remove them to properly flush). I flushed everything vacuumed to remove moisture, purged with nitrogen to remove moisture, vacuumed again. Moisture is the enemy of AC systems. Finally, autoacforum.com is where all the AC junkies hang out. Tons of good info there. |
jdamiano VPC York compressor Dealer AC Jun 28 2018, 06:55 PM
ClayPerrine
My car has the dealership installed VPC AC. I pur... Jun 28 2018, 07:09 PM
914forme Good list Clay as usual, you will also need to rep... Jun 28 2018, 07:27 PM
MarkV If you are just trying to get the system working a... Jun 28 2018, 11:53 PM
Mblizzard
If you are just trying to get the system working ... Jun 29 2018, 11:32 AM
JamesM http://redtek.com/English/product.asp?ID=18
I wou... Jun 29 2018, 03:30 PM
Chris914n6 It's more work but replacing the compressor wi... Jun 29 2018, 01:53 AM
jcd914 R134 molecules are smaller than R12 molecules and ... Jun 29 2018, 10:44 AM
Chris914n6
R134 is also not as thermally efficient as R12, s... Jun 29 2018, 02:15 PM
76-914 They can be too large. also. My power plant is out... Jun 29 2018, 11:07 AM
Chris914n6
They can be too large. also. My power plant is ou... Jun 29 2018, 02:24 PM
dr914@autoatlanta.com We only put r12 in the original 914 ac systems, DP... Jun 29 2018, 02:00 PM
914forme Well in reality it does not matter what your using... Jun 29 2018, 04:16 PM
ClayPerrine
Or switch over to an electric compressor system... Jun 30 2018, 07:47 AM
Dave_Darling Another good part about the electric compressor is... Jun 30 2018, 09:18 AM
914forme Thanks Clay, just solved two of my problems, now I... Jun 30 2018, 03:50 PM
ClayPerrine
Thanks Clay, just solved two of my problems, now ... Jun 30 2018, 04:53 PM
914forme
Thanks Clay, just solved two of my problems, now... Jun 30 2018, 07:04 PM
ClayPerrine
[quote name='ClayPerrine' post='2624968' date='Ju... Jul 1 2018, 06:07 AM
914forme This seems like a good solution for a high amp alt... Jul 1 2018, 09:05 AM
ClayPerrine Just for education purposes...
Here are some pict... Jul 1 2018, 09:48 AM
914forme
I actually tried... Jul 1 2018, 11:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:30 PM |
