> VPC York compressor Dealer AC, R134A Fill
jdamiano
post Jun 28 2018, 06:55 PM
My car has the dealership installed VPC AC. I purchased the car 5 months ago and the AC doesn’t blow cold. I have no history on it. Still had a little pressure in the system. I’m thinking of charging it with R134. Has anyone done this and know how if it will work and how much I should try to put in the system?
914forme
post Jun 29 2018, 04:16 PM
Well in reality it does not matter what your using you will need to do the follow.
Replace the dryer
Assemble the system:
Draw vacuum and make sure it holds for a period of time, that period is up to you.
If it leaks fix the leak
Rinse and repeat until it can hold vacuum longer than you can hold your breath.
Install system in car
Draw vacuum again, and test system, you may have to loop back. This did add a few steps but makes it a lot easier to fix issues and find leaks when you can flip things in 3D
Add the oil associated with your choice of Freon in the approbate amount for your system
Start the car
Fill the system to the approbate pressure for the ambient temperature
Check the system for proper functionality
Drive with out your back and undercarriage getting all swampy.
Now the highly recommended option.
New Rotary Compressor - why less load on the engine than the engine driving another piston engine. More efficient operation, and if you wanted to make the system better you use one of the more Modren units that is constantly on, and varies refrigerant flow based on need. Makes the system even more efficient. Or switch over to an electric compressor system, these can be $$$$ and I have not seen a good DIY on the controls of these yet.
jdamiano   VPC York compressor Dealer AC   Jun 28 2018, 06:55 PM
ClayPerrine   My car has the dealership installed VPC AC. I pur...   Jun 28 2018, 07:09 PM
914forme   Good list Clay as usual, you will also need to rep...   Jun 28 2018, 07:27 PM
MarkV   If you are just trying to get the system working a...   Jun 28 2018, 11:53 PM
Mblizzard   If you are just trying to get the system working ...   Jun 29 2018, 11:32 AM
JamesM   http://redtek.com/English/product.asp?ID=18 I wou...   Jun 29 2018, 03:30 PM
Chris914n6   It's more work but replacing the compressor wi...   Jun 29 2018, 01:53 AM
jcd914   R134 molecules are smaller than R12 molecules and ...   Jun 29 2018, 10:44 AM
Chris914n6   R134 is also not as thermally efficient as R12, s...   Jun 29 2018, 02:15 PM
76-914   They can be too large. also. My power plant is out...   Jun 29 2018, 11:07 AM
Chris914n6   They can be too large. also. My power plant is ou...   Jun 29 2018, 02:24 PM
Amphicar770   I redid my AC system back in 2013. Still blowing ...   Jun 29 2018, 01:43 PM
dr914@autoatlanta.com   We only put r12 in the original 914 ac systems, DP...   Jun 29 2018, 02:00 PM
914forme   Well in reality it does not matter what your using...   Jun 29 2018, 04:16 PM
ClayPerrine   Or switch over to an electric compressor system...   Jun 30 2018, 07:47 AM
Dave_Darling   Another good part about the electric compressor is...   Jun 30 2018, 09:18 AM
914forme   Thanks Clay, just solved two of my problems, now I...   Jun 30 2018, 03:50 PM
ClayPerrine   Thanks Clay, just solved two of my problems, now ...   Jun 30 2018, 04:53 PM
914forme   Thanks Clay, just solved two of my problems, now...   Jun 30 2018, 07:04 PM
ClayPerrine   [quote name='ClayPerrine' post='2624968' date='Ju...   Jul 1 2018, 06:07 AM
914forme   This seems like a good solution for a high amp alt...   Jul 1 2018, 09:05 AM
ClayPerrine   Just for education purposes... Here are some pict...   Jul 1 2018, 09:48 AM
914forme   Just for education purposes... I actually tried...   Jul 1 2018, 11:49 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:10 PM
