| jdamiano |
Jun 28 2018, 06:55 PM
Member ![]() ![]() Group: Members Posts: 336 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States |
My car has the dealership installed VPC AC. I purchased the car 5 months ago and the AC doesn’t blow cold. I have no history on it. Still had a little pressure in the system. I’m thinking of charging it with R134. Has anyone done this and know how if it will work and how much I should try to put in the system?
| 914forme |
Jun 30 2018, 03:50 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Thanks Clay, just solved two of my problems, now I don't have to run as much A/C line, all of it will be in the Frunt. (IMG:style_emoticons/default/aktion035.gif) A bit larger electrical wire, but the is easier to route than barrier hose.
BTW Clay you have the P/N for that 964 Alternator everything I have found says 115 Amp. |
jdamiano VPC York compressor Dealer AC Jun 28 2018, 06:55 PM
ClayPerrine
My car has the dealership installed VPC AC. I pur... Jun 28 2018, 07:09 PM
914forme Good list Clay as usual, you will also need to rep... Jun 28 2018, 07:27 PM
MarkV If you are just trying to get the system working a... Jun 28 2018, 11:53 PM
Mblizzard
If you are just trying to get the system working ... Jun 29 2018, 11:32 AM
JamesM http://redtek.com/English/product.asp?ID=18
I wou... Jun 29 2018, 03:30 PM
Chris914n6 It's more work but replacing the compressor wi... Jun 29 2018, 01:53 AM
jcd914 R134 molecules are smaller than R12 molecules and ... Jun 29 2018, 10:44 AM
Chris914n6
R134 is also not as thermally efficient as R12, s... Jun 29 2018, 02:15 PM
76-914 They can be too large. also. My power plant is out... Jun 29 2018, 11:07 AM
Chris914n6
They can be too large. also. My power plant is ou... Jun 29 2018, 02:24 PM
Amphicar770 I redid my AC system back in 2013. Still blowing ... Jun 29 2018, 01:43 PM
dr914@autoatlanta.com We only put r12 in the original 914 ac systems, DP... Jun 29 2018, 02:00 PM
914forme Well in reality it does not matter what your using... Jun 29 2018, 04:16 PM
ClayPerrine
Or switch over to an electric compressor system... Jun 30 2018, 07:47 AM
Dave_Darling Another good part about the electric compressor is... Jun 30 2018, 09:18 AM
ClayPerrine
Thanks Clay, just solved two of my problems, now ... Jun 30 2018, 04:53 PM
914forme
Thanks Clay, just solved two of my problems, now... Jun 30 2018, 07:04 PM
ClayPerrine
[quote name='ClayPerrine' post='2624968' date='Ju... Jul 1 2018, 06:07 AM
914forme This seems like a good solution for a high amp alt... Jul 1 2018, 09:05 AM
ClayPerrine Just for education purposes...
Here are some pict... Jul 1 2018, 09:48 AM
914forme
I actually tried... Jul 1 2018, 11:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
