> Valve collision problem
thomasotten
post Jun 30 2018, 08:03 PM
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO.
Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow.
I have a deck height of .065.
This is essentially a stock build, stock camshaft, etc.
Any ideas? Is this perhaps a valve stem lubrication issue?
sixnotfour
post Jul 1 2018, 12:17 PM
top end oiling problem ?? no lube
thomasotten   Valve collision problem   Jun 30 2018, 08:03 PM
thelogo   I am having a bit of a problem with my latest 2 l...   Jun 30 2018, 09:58 PM
Mueller   I thought if the valve gets stuck or struck th...   Jul 1 2018, 10:50 AM
euro911   Deck height at the top of the barrels is one thing...   Jul 1 2018, 04:29 AM
bdstone914   I am having a bit of a problem with my latest 2 l...   Jul 1 2018, 07:35 AM
thomasotten   Basically a stock build. But with 96mm Pistons w...   Jul 1 2018, 07:48 AM
thomasotten   Stuck intake valve   Jul 1 2018, 07:49 AM
Mark Henry   Stuck intake valve I often see this when a seat...   Jul 1 2018, 08:35 AM
Mark Henry   Stuck intake valve I often see this when a sea...   Jul 1 2018, 09:30 AM
Bartlett 914   Once the valve is bent, it is going to stick. Mayb...   Jul 1 2018, 08:20 AM
Mark Henry   Possible causes: Guides not sized/reamed/honed c...   Jul 1 2018, 08:31 AM
r_towle   pistons put in upside down?   Jul 1 2018, 10:52 AM
thomasotten   Photo of the stuck valve. When this happened to ...   Jul 1 2018, 11:21 AM
thelogo   Photo of the stuck valve. When this happened to ...   Jul 1 2018, 02:50 PM
sixnotfour   top end oiling problem ?? no lube   Jul 1 2018, 12:17 PM
Mark Henry   I'd check the clearance of the guides, most sh...   Jul 1 2018, 02:33 PM
Mark Henry   Maybe you should get your injectors checked/cleane...   Jul 1 2018, 02:36 PM
thomasotten   Maybe you should get your injectors checked/clean...   Jul 1 2018, 04:26 PM
thomasotten   So, after sitting on the workbench for a few hours...   Jul 1 2018, 05:01 PM
rgalla9146   Most likely issue is the guides are too tight.   Jul 1 2018, 05:05 PM
thomasotten   Brass shaving found mid stem   Jul 1 2018, 05:11 PM
thomasotten   It is hard to make a good photo of this, but looki...   Jul 1 2018, 05:18 PM
Elliot Cannon   Next time, send them here. :D http://www.europe...   Jul 1 2018, 05:21 PM
bulitt   They used the wrong size reamer ? Roll that valve ...   Jul 1 2018, 06:14 PM
Mark Henry   Hard to see, but definitely tight and a poor job. ...   Jul 1 2018, 07:41 PM
reharvey   I had this exact same problem once and it was the ...   Jul 2 2018, 06:13 AM
thomasotten   I won't be posting more about this until I hav...   Jul 17 2018, 10:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:41 AM
