> Valve collision problem
thomasotten
post Jun 30 2018, 08:03 PM
I am having a bit of a problem with my latest 2 liter build. Basically, valves are colliding with pistons after warm up during break in. A valve got stuck and the pushrod actually fell off the rocker.
The heads were redon by RIMCO. After the problem happened, I pulled the heads, and there was clear indication of valve collision, and I had a valve stuck open. The head with a problem was sent back to RIMCO.
Reinstalled. What happened this time is the engine start up from cold, runs fine. But then I can hear the taping of collision again. The taping is accompanied by a chirping sound that sounds like something is dragging. I think it must be the valves dragging and closing too slow.
I have a deck height of .065.
This is essentially a stock build, stock camshaft, etc.
Any ideas? Is this perhaps a valve stem lubrication issue?
Mark Henry
post Jul 1 2018, 02:33 PM
that's what I do!
I'd check the clearance of the guides, most shops use a Go-No Go gauge, but it as simple as feel for an experienced machinist, if it catches before the spring goes on it will seize when hot.
Another cause for this is bad gas, varnish, new engine always use brand new gas.
This could just be caused by your issue, but that is lean city, brown exhaust valve, bright white electrode.
thomasotten   Valve collision problem   Jun 30 2018, 08:03 PM
thelogo   I am having a bit of a problem with my latest 2 l...   Jun 30 2018, 09:58 PM
Mueller   I thought if the valve gets stuck or struck th...   Jul 1 2018, 10:50 AM
euro911   Deck height at the top of the barrels is one thing...   Jul 1 2018, 04:29 AM
bdstone914   I am having a bit of a problem with my latest 2 l...   Jul 1 2018, 07:35 AM
thomasotten   Basically a stock build. But with 96mm Pistons w...   Jul 1 2018, 07:48 AM
thomasotten   Stuck intake valve   Jul 1 2018, 07:49 AM
Mark Henry   Stuck intake valve I often see this when a seat...   Jul 1 2018, 08:35 AM
Mark Henry   Stuck intake valve I often see this when a sea...   Jul 1 2018, 09:30 AM
Bartlett 914   Once the valve is bent, it is going to stick. Mayb...   Jul 1 2018, 08:20 AM
Mark Henry   Possible causes: Guides not sized/reamed/honed c...   Jul 1 2018, 08:31 AM
r_towle   pistons put in upside down?   Jul 1 2018, 10:52 AM
thomasotten   Photo of the stuck valve. When this happened to ...   Jul 1 2018, 11:21 AM
thelogo   Photo of the stuck valve. When this happened to ...   Jul 1 2018, 02:50 PM
sixnotfour   top end oiling problem ?? no lube   Jul 1 2018, 12:17 PM
Mark Henry   I'd check the clearance of the guides, most sh...   Jul 1 2018, 02:33 PM
Mark Henry   Maybe you should get your injectors checked/cleane...   Jul 1 2018, 02:36 PM
thomasotten   Maybe you should get your injectors checked/clean...   Jul 1 2018, 04:26 PM
thomasotten   So, after sitting on the workbench for a few hours...   Jul 1 2018, 05:01 PM
rgalla9146   Most likely issue is the guides are too tight.   Jul 1 2018, 05:05 PM
thomasotten   Brass shaving found mid stem   Jul 1 2018, 05:11 PM
thomasotten   It is hard to make a good photo of this, but looki...   Jul 1 2018, 05:18 PM
Elliot Cannon   Next time, send them here. :D http://www.europe...   Jul 1 2018, 05:21 PM
bulitt   They used the wrong size reamer ? Roll that valve ...   Jul 1 2018, 06:14 PM
Mark Henry   Hard to see, but definitely tight and a poor job. ...   Jul 1 2018, 07:41 PM
reharvey   I had this exact same problem once and it was the ...   Jul 2 2018, 06:13 AM
thomasotten   I won't be posting more about this until I hav...   Jul 17 2018, 10:42 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:49 AM
