Engine problem, Cooling |
stevend914 |
Jul 3 2018, 11:04 AM
Member Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest |
My car overheats on long drives when the ambient temp gets above 80F. The car does not have the thermostat or cable attached to the cooling flappers. I've rotated the flapper rod and I can hear the flappers. Without the thermostat, the flappers should be in the open position, correct? But the car still overheats. (IMG:style_emoticons/default/hissyfit.gif) Maybe the flappers are closed? Any thoughts? Thanks
porschetub |
Jul 3 2018, 07:03 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Engine compartment seal good ? plug seals all in place ?,engine tin all present and in place?,no vacuum leaks? is the engine clean or oil and dirt covered ? and then all the stuff already mentioned,one or more or all these thing can have a huge difference in running temp,don't run your engine too long if its overheating it can really bugger up an aircooled engine in a big way.
Good luck. |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:14 AM |
